ATI Harmonic Balancer
Old Jan 22, 2022 | 03:00 AM
Pulse Red's Avatar
Default ATI Harmonic Balancer
Hi everyone,
I'm looking at upgrading my 12 year old PowerBond 25% UDP with an ATI. As I'm in Australia, the car is an 04 Holden Monaro M6 5.7 (equivalent is an 04 GTO). I think the ATI may be more suitable for high rpm and actually work better as a balancer.
However, I'm a little confused as to what is what with the ATI range. They appear to have two series? Anyone know what is the difference? Should I avoid the cheaper ones? Or is just because one lot is 10% and the other 25%? I am looking to retain A/C, or does that just mean it doesn't include the relevant pulley?.
I would have thought I would just choose the 25% version to be equivalent to what I use now, however, I'm thinking I may be better off with a 10%, as I've always felt a bit of accessory drain with the PowerBond. Just give up a HP or two. Anyone have any experience with any of these? Any known fitment issues?
ATI 918844 - 25% U/D with NO A/C
ATI 918845 - 25% U/D with 10% U/D A/C Pulley
Requires shorter belts: Gates #K060760 - 6 rib, #4040390 - 8 rib
ATI 917276 - 10% U/D with A/C Pulley
ATI 917277 - 10% U/D with NO A/C
Belt #s: A/C 4040390, and Accessories 4060775
Thanks
Old Jan 22, 2022 | 03:33 AM
QwkTrip's Avatar
The catalog does not display all choices. In fact, the catalog 10% underdrive pulley has the wrong durometer rubber for anything but stock power level. Always call ATI when making an order. They will ask you questions and customize it for your needs, including making a choice of which rubber durometer is best for your setup.
Old Jan 22, 2022 | 04:10 AM
Pulse Red's Avatar
Thanks for the response. That's very interesting info. I wasn't actually buying from the USA, I was buying in my country and they were the option I was presented with locally for items for my series of car. I thought they had imported what would be right for the market they sell to (modified cars) but perhaps not! Maybe I need to see about importing from the USA instead. If I purchased from somewhere like Summit or BTR, who export to my country, would they be able to choose the right one?
Old Jan 22, 2022 | 05:02 AM
QwkTrip's Avatar
Anybody can use the custom order form for an ATI damper, including Summit Racing. But you'll want to talk to the ATI tech support to get the part numbers and options you need. That way you can tell Summit Racing what to order for you.
Odds are you're going to end up with a 10% underdrive with 66 durometer rubbers. The 25% underdrive is just too small to be effective but ATI sells it anyway because people think they want it and it sells..
Old Jan 22, 2022 | 06:24 AM
Pulse Red's Avatar
Cool, thanks for the info. I will look into this process. Your prediction makes sense, on the GTO forums, that 10% 66 UDP seems to be what people use when purchasing the ATI.
Old Jan 22, 2022 | 01:18 PM
99 Black Bird T/A's Avatar
FWIW - the 10% UD ATI is excellent quality. After twenty years of use & ~138,000 miles, zero issues with the on my T/A.
Old Jan 22, 2022 | 04:45 PM
QwkTrip's Avatar
Correct, the catalog part for F-body 10% underdrive has something around 40 rubbers (can't remember exact number) and ATI will guide you away from that into stiffer rubber. If you need more than 66 rubber then they will probably say you need a larger (stock) diameter damper too. They'll probably recommend to inspect the rubber every 5-7 years if street driving or every 1 year if racing. Installing new rubbers is $75 + shipping. But these are all guesses and it's better to get the answers straight from the experts.
Old Jan 22, 2022 | 06:26 PM
Pulse Red's Avatar
Thanks again, probably unlikely need more than 66 as my car is just a street car with a small cam + heads and all the other usual bits but I do shift at 7000 rpm, so I think the ATI could be worthwhile. I've sent ATI a message anyway.
Old Jan 23, 2022 | 05:16 PM
91 Z28's Avatar
Oh boy I've got ATI 917277 and I didn't realise it has the 40 durometer rubber in there. Sounds like I should pull mine and send it in to get 66 rubber installed. I've only really just started my engine but it's geared towards at least 1000 HP
Old Jan 23, 2022 | 05:47 PM
QwkTrip's Avatar
The durometer is stamped in the metal ring on back of damper if you want to verify what you have.
Old Jan 23, 2022 | 05:52 PM
91 Z28's Avatar
Cool thanks man. I'll definitely have to check it out. It'll have the 40 rubber in there but I was totally unaware it was for basically stock power. I just sent ATI an email to figure out costs on getting them to rebuild it. Better safe then sorry, it's cost me too much to risk it. Plus it's winter here
Old Jan 24, 2022 | 03:17 PM
Pulse Red's Avatar
I got a response back from ATI, just told me to purchase a completely standard diameter unit. Nothing else was said. This was a surprise to me. I've asked a few questions but I won't hear from them for a bit due to time zone differences I would imagine.
Old Jan 24, 2022 | 03:30 PM
QwkTrip's Avatar
Yes, larger diameter unit does offer the best protection and is the right choice from that perspective. But you really need to talk to somebody in a live conversation to talk through pro's and con's of other options. That's how you'll get them to open up and talk more. They have to be more careful what they put in writing in an e-mail.
