coolant reservoir?
I have dual fans on my radiator as well but I need a good overflow.
I run a 160 deg, 200deg would be pretty normal temp for a stock thermostat to run at.
But if its pinging then you either have some bad gas, or bad tune, or its REALLY hot.
How is your intake setup? If its sucking hot air from the engine bay that will only make pinging worse.
Thanks for the info.
