Safest way to install harmonic balancer?
Old Jul 23, 2004 | 06:36 AM
GTS346's Avatar
Default Safest way to install harmonic balancer?
What's the safest way to reinstall a harmonic balancer to an LS1?
Without damaging crankshaft end or chipping anything?
Are they always hard to get on?
Old Jul 23, 2004 | 07:26 AM
boomcase's Avatar
Beat It With A Hammer ,, Lol Just Kidding, I Just Had To Tap Mine On Alittle Then I Used The Old Bolt To Tighten It Down , Then Took Out The Old Bolt And Installed The New One And Torqued It Down To 220lb..
Old Jul 23, 2004 | 08:20 AM
technical's Avatar
You might need to tap it on with a hammer to get it started. Don't use the crank bolt to draw it on because it's too short and might strip the threads out of the crank. Get a longer bolt that's the same size or buy one of 2xls1's install tools for $25.
Also, when you put the new bolt in, the spec is 37ft/lbs + 140 degrees. It's a torque to yield bolt unless you buy an ARP bolt which may have a torque spec, but I don't know it off hand.
Old Jul 23, 2004 | 08:31 AM
HavATampa's Avatar
Send 2xLS1 a PM, he'll set you up with one of his pulley install tools. Here's the link to the page for more info:
https://ls1tech.com/forums/showthread.php?t=158854
Old Jul 23, 2004 | 05:35 PM
2xLS1's Avatar
As of right now, I only have 9 left and when they are gone, I won't be selling any more.
Old Jul 24, 2004 | 03:18 PM
PowerSpooge's Avatar
AutoZone has what you need as part of their free tool program. Pay for it, use it, return it for a full refund.
Old Jul 24, 2004 | 06:01 PM
2xLS1's Avatar
Yea right. Show me the pulley installer here. Let alone one with metric threads. Want to guess why I won't be selling any more?
http://www.autozone.com/servlet/UiBr...oan_a_tool.jsp
Old Jul 25, 2004 | 04:33 AM
GTS346's Avatar
2xLS1 thanks for the offer on your install tool, it would of came in handy today.
But me being in Australia would take 2 weeks to get it here, I got the pulley on after about 1/2 hours worth of rubber mallet tapping.
If your tool your selling does the trick like everyone says, then heck you gotta be crazy not to own 1 as the mallet method is a ball breaker.
