Coolant issue
Old Oct 8, 2022 | 01:40 PM
  #61
Originally Posted by Tyler Dietzenbach
April 19. Thinking I will find the issue on the other side where the loose bolts were.
That would be my hunch. Curious to see that head. Should be one (or two??) very clean chamber and valves
Old Oct 8, 2022 | 03:10 PM
  #62
Tyler Dietzenbach's Avatar
Here are the drivers side photos
Old Oct 8, 2022 | 03:12 PM
  #63
Old Oct 8, 2022 | 03:29 PM
  #64
01CamaroSSTx's Avatar
Well hell that didn't tell us much either. Did you smell coolant at any time and was the rear steam port seals also replaced? It's really hard to say that it's still not a head gasket causing the issue and I'm with you on the light coat of Permatex copper spray on the head gaskets. Looks like there's still some old gasket material left on the block so get everything cleaned up really well and the holes in the block cleared of coolant and I would have those cylinder heads checked out also.
Sorry for your troubles brother and hope this time around she's good to go!
Old Oct 8, 2022 | 03:49 PM
  #65
I'm going to clean up the block as best I can, yeah there is some **** I couldn't really get off before. I never smelled coolant.
Here is the top of a piston on this side.
Old Oct 8, 2022 | 04:55 PM
  #66
I'm being told this is from coolant
Old Oct 8, 2022 | 08:54 PM
  #67
I think the moral of this story will be cleaning the heads far better and having a calibrated torque wrench.
Old Oct 10, 2022 | 02:07 PM
  #68
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Any affected combustion chambers might not be showing a ton of coolant "cleaning" due to the fact that the internal leak might have been pretty minor until recently. Reason being, the other coolant leak that was recently repaired (water pump/t-stat housing) could have been a greater weak point, acting as pressure relief for the system. This would explain why the problem seemed to have worsened just as soon as you buttoned up all other leaks/possible leaks.
So don't be too discouraged by the lack of obvious evidence regarding long term coolant exposure to any given cylinder. Regardless, those loose head bolts were a problem, and now that will be solved (along with the cleaner gasket mating surface).
Old Oct 11, 2022 | 08:39 AM
  #69
Default Update
Drove it around last night for over an hour and did some pulls. Its remained full. I'm hesistant to say resolved after this but..there you have it.
Old Oct 11, 2022 | 11:48 PM
  #70
Been driving it around quite a bit today and not 1 drop of coolant loss..Finally..
Old Oct 12, 2022 | 12:33 AM
  #71
Looks like the drivers head/block juncture was the issue...
Sure glad it looks like it is SOLVED!
Old Oct 12, 2022 | 02:10 PM
  #72
RPM WS6's Avatar
Great news on the continued positive result!
Old Oct 12, 2022 | 10:57 PM
  #73
CattleAc's Avatar
Thanks for getting back with your results...always good to see a positive follow up.
Old Oct 12, 2022 | 11:04 PM
  #74
Absolutely! Despite what my profile says, I've been on Ls1tech for about 12 years. I wish I could get my old profile combined with this one if the mods are listening lol......
Anyway, I can't stand it when threads don't have a solution or final post.
Old Oct 12, 2022 | 11:32 PM
  #75
Well, it's been another day. Still good??
Old Oct 12, 2022 | 11:36 PM
  #76
Sure is! Runs fantastic, no coolant loss.
Old Oct 13, 2022 | 12:35 AM
  #77
Nice!!
Old Oct 13, 2022 | 01:29 AM
  #78
RPM WS6's Avatar
The merge isn't something we can do, but if you have an access issue with your old account and would like to regain access, that's something I could help with.
Old Oct 13, 2022 | 09:25 PM
  #79
RevGTO's Avatar
Pontiacerator
Not to be a party pooper, but that coolant looks a little milky. Did you do a flush? I know people debate the merits of flushing, but some old degraded coolant with combustion byproducts may still be circulating in the system.
Otherwise, glad you're up and running well.
Old Oct 14, 2022 | 09:34 AM
  #80
I think the glare is playing tricks on you. I've had this coolant replaced like 3 times in the last 2 years lol. Some for "fun" reasons and some not. It is pure dex. I'll grab another picture to be sure.
