Who makes 2" headers that fit Fbodies?
Old Oct 4, 2022 | 05:46 PM
Gripenfelter's Avatar
Default Who makes 2" headers that fit Fbodies?
I have a 427. Running 1 7/8" headers but I'd like to step up to 2" headers. Anyone make a set that will fit our cars?
Car is a 2001 Trans Am.
Old Oct 4, 2022 | 06:38 PM
99 Black Bird T/A's Avatar
Does your car have an aftermarket light weight K-member? When I asked same question in 2017 was told by a couple of vendors the light weight tublar k member really opens up the options for different brands of 2 inch headers to fit.
IIRC DynaTech has a 2 inch that fits the stock K member with minimal clearancing typically required around the stock k member. The 2 inch Kook's fit with more clearancing around the stock k member required.
I didn't want to get a light weight tublar k member or deal with clearancing so stuck with 1 7/8 Kook's.
Old Oct 4, 2022 | 06:52 PM
Yes, I have an aftermarket K member.
Old Oct 4, 2022 | 10:28 PM
brutalzo6's Avatar
American racing headers make a very nice fitting 2” headers
Old Oct 9, 2022 | 06:27 PM
jetech's Avatar
Veteran: Air Force
Interesting calculator
Old Oct 9, 2022 | 08:11 PM
onebadbowtie86's Avatar
I have the texas speed 2" headers on my car and they fit nice.
Old Oct 9, 2022 | 09:02 PM
SAPPER's Avatar
My question is...Why!
That 1/8" isn't gonna make any real difference. Now if you were stepping up from 1-3/4" then yes
Now if your current headers are beat up, trashed and ready for a new set. Then that would be a good reason to get 2". But if it's just for the sake of the oooo--aaahhhh of having 2" primaries, well it's your money.
Old Oct 9, 2022 | 10:21 PM
84ta406's Avatar
How much power are you making? If it's under 700fwhp, 2" primaries really won't make any difference based on testing.
Old Oct 10, 2022 | 09:09 PM
Our local dyno has shown gains of 7-8 rwhp over the 1 7/8" if you are above 600 rwhp and running a 427 or bigger.
Old Oct 11, 2022 | 07:24 PM
Many threads on Corvette Forum showing gains with 2’ headers over 1 7/8’ headers. 2 1/8” headers show even more gains over 1 7/8” at rpm. ARH in my opinion make the highest quality set. I have a set on my Chevelle and it’s quality from flange to collector. Great choice of header for your F-Body.
Old Oct 12, 2022 | 06:11 AM
ramairetransam's Avatar
texas speed makes a set
Old Oct 12, 2022 | 06:35 AM
84ta406's Avatar
I can see that, that's why I asked how much power. 700 fwhp is probably pretty close to that 600rwhp number. And you have to keep those big engines breathing especially if you're turning RPM. I know on my 402 and 660+ going from 1 3/4 to 1 7/8 was only worth like 10hp at peak on the engine Dyno, but I'm not turning a lot of rpm either, peak at 6650.
Different chassis but we made the most HP with a set of ARH headers, very nice build quality on them.
Old Oct 29, 2022 | 06:34 PM
FCar2000TA's Avatar
Veteran: Air Force
I think Kooks is the best option. I have their true-dual over-the-axle exhaust and 1 7/8 headers on my LS1, and it sounds better than any non-Kooks exhaust sound byte or video that I listened to. It is expensive, but it just sounds right... unless you prefer crackles and pops in your exhaust note.
