Is this LS6 intake safe to use?
Old Nov 2, 2022 | 10:57 PM
Early Cuyler's Avatar
Default Is this LS6 intake safe to use?
I bought this LS6 intake on Ebay. The price seemed a little too good to be true, but the seller didn't disclose any damage to the intake whatsoever, so I took a chance and bought it.
The intake arrived with a crack at the base of the intake, extremely dirty, and full of junk. (pics below)
Is this intake worth cleaning up and using, or should I just save myself the trouble and return it? Would it be unsafe to use with that crack being close to an intake runner?
What do you think? Thanks in advance!
Old Nov 3, 2022 | 06:20 AM
Old Buzzard's Avatar
Send it back and then give the seller a thumbs down.
Old Nov 3, 2022 | 10:08 AM
I don't think the crack would spread to the runner, BUT having said that, I would send it back.
Seller is sloppy for sending something like that out.
Old Nov 3, 2022 | 08:10 PM
jetech's Avatar
Veteran: Air Force
Hey Early Cuyler, you shouldn't use it...you should probably let me recycle it for you!
Old Nov 3, 2022 | 09:01 PM
99 Black Bird T/A's Avatar
My first worry would be if the price was too good to be true are you sure it's an LS6 intake?
Any pictures of the bottom underside?
On the underside is the bottom flat on the intake manifold?
Old Nov 3, 2022 | 10:17 PM
Yes its flat and it has the ls6 intake part number stamped on
Old Nov 4, 2022 | 07:23 AM
Totally off topic here, but are you in Ellijay?
