Popping during acceleration
Old Nov 1, 2022 | 07:30 PM
Nflynn671's Avatar
Default Popping during acceleration
Swapped an LQ4 into a 1979 Camaro
have sloppy stage 2 cam with a tune/rest is stock
no cats, 3” inch exhaust out the back
Car is popping during acceleration only till about 1600 ish rpm then runs and sounds completely normal.
was thinking it could be an exhaust leak as one of my clamps is black right where it could leak, picture below
The popping does sound like it’s coming from around this clamp, couldn’t see any leaks but it did sound like it was from around the clamp
No codes showing up, was wondering if anyone could tell me if they think it’s also an exhaust leak, can’t work on it for a few days so I just want to be prepared to check other potential things wrong with it.
Also just some more info, it used to do the same popping when it was cold so I would just let it warm up more before driving, now it is doing that same pop while warm but only during acceleration below like 1600ish rpm
These are some videos of the sound, it is coming from the exhaust, can’t tell if from where I think it’s leaking or just out the back
https://youtube.com/shorts/VhFWp_uvK6E?feature=share
https://youtube.com/shorts/lBetlGrhIBc?feature=share
https://youtu.be/TLM-q1YRGu8
Another edit, doesn’t happen when cold but will happen after the motor has been warm for a while, my guess is that it’s an exhaust leak because it started happening again a few minutes after it was warm so the exhaust heated up.
Old Nov 1, 2022 | 07:41 PM
Can you send a sound clip?
Old Nov 1, 2022 | 07:43 PM
Nflynn671's Avatar
I will send one tomorrow, neighbors would have a heart attack if I ran it for a while tonight
Old Nov 2, 2022 | 12:31 PM
Nflynn671's Avatar
i put some links to Clips of it, the ones that are black are from inside the car and the other is outside, the sound is coming somewhere from the exhaust, can’t tell if it’s from where I think it’s leaking or the back
Old Nov 3, 2022 | 08:25 PM
jetech's Avatar
Veteran: Air Force
Did this happen right after the swap or has it been sounding/driving normal for a while before the popping started?
Old Nov 3, 2022 | 08:26 PM
Nflynn671's Avatar
it just started the other day, and it doesn’t do it until a while after the engine warms up which makes me think it’s the exhaust getting hot and expanding
Old Nov 3, 2022 | 10:57 PM
jetech's Avatar
Veteran: Air Force
It doesn't sound like and exhaust leak to me from those videos.
Old Nov 4, 2022 | 01:28 AM
Nflynn671's Avatar
now idk if this could be related but it happened after it rained kinda slow for about 2 days straight, from what I read online my only guesses would be coils, wires or plugs which the plugs are new and I thought if it was those it’d affect at all rpms, or an exhaust leak
Old Nov 4, 2022 | 01:55 AM
Nflynn671's Avatar
i found a video with a similar sound from the exhaust,
which is why I suspect a coil
Old Nov 4, 2022 | 09:18 AM
jetech's Avatar
Veteran: Air Force
Do you have access to a scanner with live data?
Old Nov 4, 2022 | 09:48 AM
Nflynn671's Avatar
tomorrow I will
Old Nov 4, 2022 | 09:55 AM
Sounds like a good ol' intermittent miss. My Tahoe had one on #5 cyl., so I suspected a plug or wire. Pulled that wire, and discoverd it had worn thru on the steering shaft that it ran next to. The way it looked,it should not have worked at all! Yet it would not miss when steady running down the highway.
Bottom line, it could be as simple as a bad plug, wire, or coil, IF down to one cyl.
Any codes showing yet? If jumping between holes, plugs and/or wires likely.
Old Nov 4, 2022 | 12:16 PM
jetech's Avatar
Veteran: Air Force
I agree with G Atsma, Probably a miss. The cylinder misfires(not burning the fuel introduced into the cylinder) then sometime later it ignites that cylinder which is now overly saturated with fuel and you hear the backfire
