Ls Intakes
Old Jan 1, 2023 | 05:41 PM
bjrs2k's Avatar
Default Ls Intakes
I’m building a turbo ls engine. 4.8 rotating assembly with ls7 pistons, I’m trying to decide whether or not to use a stock intake. I was told the ls6 ones crack under too much boost, I’ve also seen that the aluminum hi flow intakes are really loud and amplify the noise of the valvetrain. Any suggestions or can anyone tell me if these are true or are not
Old Jan 1, 2023 | 06:40 PM
Give us details of your setup please. What block are you using to get a 4.125 bore? Rods? Crank? Details first please.
Old Jan 1, 2023 | 07:01 PM
bjrs2k's Avatar
Lq9 bored out to 4.185” with a 4.200” .041” thick gasket and 4.8 rods and crank
rods are 6.298” and the stroke is 3.268”
243 heads and the combustion chamber is being opened up from 65cc to 70cc
Old Jan 1, 2023 | 07:25 PM
LS1Formulation's Avatar
LQ9 cannot be bored that far. It's not a siamesed bore block for one thing. For another, hitting .060 over is pushing it. .185 over? Uh... no.
Old Jan 1, 2023 | 07:33 PM
.185 bore? If there’s any cylinder wall left, and that’s a big IF…you don’t want to boost it. Just not enough wall left to handle any boost. Bad idea. Now the crank is interesting. Is it a billet Bryant crank by chance? What rod is that? Cool build for sure. Interesting head choice also for that bore size.
Old Jan 1, 2023 | 08:14 PM
99 Black Bird T/A's Avatar
Most I've ever read about was on SpeedTalk where Joe Sherman/Joe Sherman Racing did a lot of sonic checks on LQ4/LQ9 and discovered ~1 in 10 or so could be bored to about ~4.125
Old Jan 2, 2023 | 08:05 AM
I've definitely seen them taken to 4.100 on an NA build, and could see them possibly going to 4.125 on a block with zero core shift, but 4.185 seems ludicrous to me. The cylinder walls would be transparent!
Old Jan 2, 2023 | 08:13 AM
Agreed
Transparant cast iron...wink
Old Jan 2, 2023 | 06:04 PM
rednari2's Avatar
I guess its decided as to how far the block can be bored. As to LS6 manifolds, they can handle boost.
