Perma-cool 19111 review?
Old Mar 28, 2023 | 03:50 PM
Magonsterz's Avatar
Default Perma-cool 19111 review?
Anyone running these with success?
Current set up is twin spall 11" pulling an advertised 1350 at 0 static.
Finishing build, adding full sized intercooler sandwiched between VA condenser and 2 core x 1.250 inner tubed Entropy radiator.
Should be fine but 100 degree Cali weather is coming.
Perma-Cool states 2800 cfm.
Perma-Cool 19111 11" High Performance Electric Fan Puller
Old Oct 29, 2023 | 12:56 AM
crispytoast's Avatar
Kind of an old thread...did u end up trying the 19111? How were they?
Old Oct 29, 2023 | 12:50 PM
Magonsterz's Avatar
i did not ended up wiring up with 3 relay set up allowing both fans to come on sharing 12 volts allowing true low on dual fan operation and not a staggered set up. Once hits 205 deg full 12 v to each is tripped and temps drop right on cue. Best mod ive ever done for the cost of a relay.
Old Nov 2, 2023 | 05:47 PM
sjsingle1's Avatar
care to do a write up on how to ?
Old Nov 2, 2023 | 10:57 PM
Magonsterz's Avatar
Old Nov 3, 2023 | 02:08 AM
sjsingle1's Avatar
does it use any of the stock relays ...or use 3 new relays ?
Old Nov 3, 2023 | 10:41 AM
A 5 pole relay is a 5 pole relay. New would be better. Nothing holy about stock ones.
Old Nov 3, 2023 | 11:42 AM
Magonsterz's Avatar
I tend to go over board on anything i do so utilized new 40 amp bosch relays, crimped, silver soldered and shrink wrapped harness but im sure any ol' local parts store relay will do.
Old Nov 3, 2023 | 04:50 PM
sjsingle1's Avatar
i guess I need to clarify my question....stock it uses ...X ...amount of relays ....and you added ....X ...amount to it ? I am not familiar at all with the stock setup
Old Nov 3, 2023 | 05:27 PM
You're overthinking it. Wire according to the above diagram and IT WILL WORK.
Does not matter what was, this is what is.
Old Nov 4, 2023 | 11:31 AM
Magonsterz's Avatar
Not knowing your current set up I would most def install a 3 new independent set as described in diagram vs attempting to decipher what is triggering current set up, pcm, temp probe or both, splitting harness to tie in a 3rd relay, etc.
