LS6 Build Advice
Old May 15, 2023 | 01:10 PM
4G63_LS6's Avatar
Default LS6 Build Advice
I'm hoping to tap into the vast knowledge and experience here to help steer me right with my new LS6 build. I'm working with a very low mile C5Z LS6 that I'd like to bring up to modern times levels of fun. The car is being built up to be a very well-rounded street car that will see time in local/regional level autox and will likely see some (limited) time on the road course as I pursue driving instruction. I don't have a hard target power goal that I have to hit, but I would like to see around 420-450whp SAE corrected on premium fuel (I'm at 4000-5000ft ASL) while still retaining low-speed drivability and power delivery. A strong, well-balanced powerband that can still pull to 6500 or more is my primary goal. I'd take a bit more midrange bark over a little extra over-rev..
I've got a preliminary build outlined and I'm ready to get parts on order, however before I committed to this combination I'd like to run this by folks more in-the-know than myself to hopefully help steer me straight of any mistakes. Anyway, here's a slightly summarized version what I've got planned.. I'm hoping to get some guidance on camshaft selection..
Halltech KillerBee II Intake
90mm TB
FAST 92 Intake Manifold (ported?)
Trick Flow GenX 215cc Heads w/ CNC Port & Chamber
Harland Sharp 1.7 rockers
New LS7 OEM Lifters
BTR Stage 1 or Comp Cams 223/231 LSR (54-457-11) - Anything else?
Katech C5R chain
ATI (10% underdrive)
Kooks 1 3/4 LTH through OEM Ti Exhaust
Love to hear your thoughts, suggestions, and input.
Thanks for your time,
- J
Old May 15, 2023 | 01:19 PM
You might want to check into the Summit Ghost Cam (222/243, 115+3, .600/.575)
Lots of good results with it.
Old May 15, 2023 | 03:11 PM
ddnspider's Avatar
Harland Sharp rockers go directly in the trash. Do a trunion upgrade to the stockers.
Old May 15, 2023 | 04:01 PM
B4CMaro's Avatar
90mm TB
​​​​​​go with a nick williams 102
Go with a fast 102 port matched to heads
oem rockers with trunnion upgrade
New LS7 OEM Lifters
Get cam motion to build you a custom cam. And probably be cheaper
Katech C5R chain
You will probably wont see 450 wheel at your altitude but who knows?
Old May 16, 2023 | 06:00 AM
SylviaStover's Avatar
Thanks for the advice
Old May 22, 2023 | 11:30 AM
02EBC5Z06's Avatar
90mm TB
GO WITH A KATECH 103 C5 TB. YOU WILL NEED TO HAVE YOUR TUNER SET MAX THROTTLE PERCENTAGE TO 93-95% TO NOT CAUSE REP.
New LS7 OEM Lifters
Katech C5R chain
Updated the TB line. Agreed on everything else though. Realistically, if you can get the compression up a bit (around 11:1) this would be a great setup and probably make around 460 wheel or so on a dynojet SAE.
Old May 22, 2023 | 12:17 PM
4G63_LS6's Avatar
I appreciate the input and feedback from everyone! Thank you.
I see a lot of recommendation to keep the OE rockers w/ the trunnion upgrade, however I understand the TFS heads need to use roller rockers due to the guide material and the side loading the OE rockers would put on them creating excessive wear. Is this not the case?
If the TFS heads do in fact need a roller rocker, and the HS rockers that were suggested by TFS are trash, what would be an appropriate rocker to use?
Old May 22, 2023 | 12:38 PM
Do you already have the heads? If not, they are available with iron guides.
02EBC5Z06's Avatar
I suggest purchasing the heads through BTR and choosing the powdered metal guide option. They will order the heads through TEA and have the work you want completed.
Old May 22, 2023 | 01:39 PM
4G63_LS6's Avatar
I do not yet have the heads. I wanted to suss out the setup before plunking down the coin for everything.
Old May 22, 2023 | 02:22 PM
OK, then get the iron guides. Rocker issue solved.
Old May 23, 2023 | 09:48 AM
4G63_LS6's Avatar
Contacted Cam Motion regarding the plans and they suggested their "Track Weapon" cam
https://cammotion.com/ls-camshafts/l...220-232-110-4/
220/232 110+4 .595"/.586" lift
Pretty different than most offerings available. Any thoughts? Seems this is a relatively new offering so it doesn't appear to have much use at this time.
Old May 23, 2023 | 09:52 AM
4G63_LS6's Avatar
Listing shows it's unavailable.
https://www.summitracing.com/parts/sum-8715
I may end up picking up 2-3 cams to help me get some real world experience and broaden my understanding of what my setup will like, yet work well with my intended use.
Appreciate the suggestions folks!!
Old May 23, 2023 | 01:03 PM
Not surprised. Likely selling the **** outta them.
Old May 23, 2023 | 04:36 PM
HioSSilver's Avatar
I made 451whp/423wtq with a bolt on 2002 ls6 through a 9" and on pump gas. No reason your ls6 or any other ls6 wouldn't do the same. All it takes is paying attention to the details.
You don't need a h/c to it.
Old May 26, 2023 | 11:35 PM
B4CMaro's Avatar
yes go with tooley prepped heads with PM guides. see if cam motion can grind that cam with a bit more lift. Have tooley setup and shim springs accordingly.
You don't want that summit cam. Wont make as much midrange power as that cam motion cam. Especially at elevation.
And dont do a UD pulley if you are running all the accessories. Slowing the water pump and alternator down is not a good thing. A replacement style fluidampr will do the trick
Old May 29, 2023 | 10:24 AM
.boB's Avatar
Because of your altitude, you can run a bit more static compression than at sea level. Calculate your dynamic compression ratio, using the cam specs you're interested in.
For road racing and autocross, your big goal is to make a really flat torque curve. You want to be able to pull out of the corners without a lot of shifting.
There are a couple of good software packages available that will help you build the engine. Although not incredibly accurate, they are consistent. You can see what happens with different cams, and allows you to play around with various specs to see what you want.
Set it up to use E-85 on race/track days. Higher octane, cleaner burning, and you'll never overheat.
