Any better fans than Derale 16925??
Old 07-29-2024 | 12:12 PM
customblackbird's Avatar
I run a flexalite flex wave 16" pulled with full shroud and its able to keep my 5.3 cool enough which I run on a flexalite variable speed controller. I'm going to try brushless fan as I do see creep once I'm sitting still. I could use the flexalite as a backup and mount it as a pusher but I don't think its necessary. Motor only pulled 14.5amps and about 180ish watts on the motor mounted to my dual 1" core radiator. It's not a bad fan but I don't like that the fan is made in china.
I run Derale dual 13" on my turbo firebird which I believe are Spal fans, they are prob 5-6years old and still work good. I'm using a flexalite variable speed controller with those as well.
