Most streetable full exhaust?
You are correct that many of the exhaust systems that were once readily available (brand new) for these cars have gone away over the years, leaving the only option being a used system (or something custom made with a specific muffler(s) if you want something very specific that was recommended in the past. The ideal system for what you're trying to accomplish would have been the SLP dual/dual catback, which hasn't been available new for a very long time but was offered as a factory option on LS1 SS cars and standard on LS1 Firehawks (therefore many systems were produced). But shipping used exhaust systems around the country is very expensive, so unless you can find a local system for sale this might not be the best option.
There are things you can do to pretty much any catback system to reduce the volume level without having any significant impact on flow. The most obvious option would be to add resonators/bullet mufflers to the I-pipe (or instead/additionally to the tail pipes). There are small diameter, straight-thru products of this nature that will fit in tight spaces and tone down the volume a bit. This might be something that you will have to do if you want an aftermarket system to be as quiet as the factory system.
Exhaust sound/volume recommendations are extremely difficult to make as everyone has a different definition of "wake the dead". Personally, I find the factory LS1 system to be MUCH too quiet for a performance V8 car (to the point of being boring), so what I consider to be a "good" sound of reasonable volume might be super loud to you. It's just so subjective.
I had this catback system on my 99 Z28 and I liked it. It’s adjustable but I kept the one side capped completely off. It was a little bit louder than stock but certainly not obnoxious. I didn’t have headers and used the stock y pipe.
Keep in mind that headers will increase sound especially if your y pipe has bigger tubing, but it’s not over the top.
What about this for an idea. What about a Y pipe with just one cat? I have a car that came with duals and it had 4 cats. I removed two and the sound volume increased quite a bit. It’s OBDI though, so there weren't any check engine lights to contend with.
I think AIR delete is a given though. Does Kooks or ARH ever offer an option to retain the AIR system?
Hooker Headers
I run this on my 98 Z28 - excellent fit, though I had to lose the conv't floor brace
Hooker Headers
That system you have posted above is nice, and would pass inspection if using the version intended for the stock Y-pipe (thus retaining stock manifolds & cats). But no system will technically be emissions compliant if the OP plans on LT headers (which he has mentioned a couple times above), regardless of a Y or H pipe arrangement. Any LT headers will necessitate a relocation of the cats, rendering the car unable to pass the strictest of visual inspections - but that's not necessarily a concern in some locations (and even less of a concern as these cars are now reaching 25 year old status, making new exemption options available in some areas).
On a side note, the "50 state legal" version of that system is listed for 1998-2002. But it can't possibly be a direct bolt-on for a 1998-99 car as the passenger side Y-pipe would have to be cut after the cat. On your '98, did you weld it place or just do some sort of clamp or custom flange on that passenger side?
Headers did not enter the picture as I wish the car to be emissions compliant for resale if needed.
How does a full Hooker long tube plus H pipe setup like the one you suggested compare to something like an American Racing LT, Y pipe, going to a Magnaflow/Borla/Corsa exhaust given the weekend warrior use case of the car?
For me, I never incorporate cats into any of my custom exhaust setups, especially ones that involve headers, so true dual is always my preference whenever there is a way to make it fit. Only way I would consider leaving the cats is if/when I don't have any intention of pulling the manifolds.
