Low Mile Per Hour after LT install
How accurate do you guys think the old adage “one mph in the 1/4 equals ten horsepower,” is? I bet surely y’all have heard that one. I haven’t modified and raced enough to say that I’m an old pro or anything like that, but once I added an additional 109 rear wheel horsepower and I picked up a little over ten mph in the 1/8 mile. I think it was about twelve mph faster and a second quicker. If the adage is anywhere close to being accurate a fifty horsepower gain and a five mph increase in trap speed seems a little lofty for a bolt-on part. Fifty horses and five mph even seems like a lot for a “full exhaust” to be honest, but I guess it happens?
WITH a proper tune, I think 3-5 is realistic.
10mph is a good gain in the 8th with 100rwhp! Was that with a power adder?
Im sure the OP will see a nice difference with the tune!
The following users liked this post:
Y2K_Frenzy (04-11-2024)
LS1Tech Administrator
Received 1,552 Likes
This I can agree with, especially for a car that's starting from a 100% stock tune. Even without the headers or any hard modifications at all, there is usually a bit to be gained from tuning, ~1mph or so, maybe a bit more in some cases. So when adding LT headers and simultaneously tuning for such, as well as generally cleaning up the stock tune, I think a total of 3-5mph is realistic. That is, assuming that the rest of the exhaust system can keep up and not inhibit the gains from the LTs (such as poor flowing/poor condition cats, subpar exhaust system/muffler, etc.)
Same old adage with weight, every 100lbs is a tenth. 5mph is not a “set” number, nor is it the average.
I wonder if the OP’s is an auto or manual? If auto have the tuner guy play with the transmission tuning. If it’s a manual, maybe his mph is “low” partly due to the driver. It takes a butt-load of runs to become “good.” I haven’t been to the track in a long time and when I was going I can’t ever say that I was “good.” After headers maybe throw some tires on that monster. Especially if it’s a manual.
Yeah it was with 6-8 psi kit on a push rod 5.0 so it wasn’t exactly setting the world on fire but it was a decent gain. Prior to the blower it would do something like 70 mph in the 1/8 and after the best I did was 82 but I may have been running with a clogged cat at that time, I can’t recall anymore. The tires were also fairly cruddy so I pretty much had to drive out of the hole and then get on it.
I bet the bog is gone after the tune. Good luck and let us know. My Z28 is an auto as well and it’s stock at the moment so I’ll be following your progress. Two tenths of a second knocked off of an e/t isn’t anything to sneeze at really for what that’s worth.
CrimsonT/A (04-11-2024)
Thanks Y2K. I'll let you know how it goes 🤘🏻
Y2K_Frenzy (04-12-2024)
Update!
Got the car back from the tune today and while I wasn't able to get a chance to play around with it this afternoon I can tell you that I was a bit shocked at the Dyno result. My previous Dyno was 301 hp and 291 tq. On same Mustang Dyno it made 336 hp and 358 tq. (The Dyno jet adjustment is 366 hp if anyone's wondering). A 35 hp gain is great but a 67 tq gain is a crazy high number , what's everyone's thoughts on that?
If I get a chance to take her out tonight, I'll let you know how it feels.
Update!
you got a torque converter in that thing yet? If not, that should be ur next mod as that tends to make the biggest difference in acceleration times.
that sounds about right. Most make 330-350 depending on how generous the dyno is that day. I think My last bolt on fbody made 344hp, within margin.
I have a 3k stall and cooler picked out from Hawks Motorsports. Planning that in a few months.
For an A4 '98-'00 LS1 with just catted LTs and lid/CAI, even with a pulley, the numbers seem high for a Mustang dyno (and the DynoJet adjustment seems especially high...nearly 370rwhp for those mods?...sounds like a "happy" dyno to me), but the real tale will be told by your new trap speeds. Did they lock the converter on the dyno? Do you have any modifications not listed in your signature?
Again, I just wouldn't get too excited until you see the new trap speeds.
Very nice. Just curious but did they adjust the shift points and torque management this time or last? If so, is there any discernible difference vs stock?
#32
#33
I was surprised by that answer but according to what he said the way the transmission is running right now is exactly where it needs to be...
Having said that, I think I'm going to have a trans go shift kit installed along with the stall converter this summer.
Y2K_Frenzy (04-14-2024)
#34
Quick update:
I was able to play around with the car a little over the weekend and it is much MUCH more fun to drive. Where my bottom end was heavily impacted previously, now have traction problems again even with the Toyo R888-R's. I'm very happy with the tune and I can absolutely feel a big difference in power. What will that equate to on draggy or the track.. we'll find out.
#35
Quick update:
Keep us updated 👍
The following 2 users liked this post by JacobChevys:
CrimsonT/A (04-14-2024), Y2K_Frenzy (04-14-2024)
#36
#37
I'd go with a bigger stall than 3k..the common converter alot of people go with is a 3600 for a bolt on car. Or even 4000 depending what you use the car for. Also don't cheap out, a good converter will make or break how it performs. Go with a good brand like yank, FTI, circle D, PTC etc..If you plan on keeping it a bolt on only you'll want more stall as the less power you make the tighter the converter will feel. Start adding heads, cam and intake and the converter will get looser the more power you make. With a full weight TA, bolt ons and tune and a 3600-4000 stall you should easily drop a second in ET.
Y2K_Frenzy (04-16-2024)
#38
CrimsonT/A (04-16-2024)
#39
#40
How “loose” of a converter does one want or need if there isn’t a drag strip around? What’s usually the actual stall or a 3600 stall converter in a 300 and some odd rear horse car? Will most of them really stall that high or does it take more than bolt-on power to get it up there? Since this is a street car maybe focus on shift extension more so than stall speed. How often are you going to launch it at 3k?
on that note, when I bought the car there was a hypertech tuner that came with it that I know can firm up the shift points. Has anyone firmed shift points with a tuner and if so how much firmer is safe to go?
