To 2 step or not 2 step?
Old Sep 14, 2024 | 09:36 AM
66OldsLS's Avatar
Default To 2 step or not 2 step?
For future reference I’m interested in putting a two step in my car. Not exactly certain of the ins and outs of how well a 2 step combination is with my setup. 6.0L LS, 4L85E auto. 3200 Circle D stall converter. I would like to install a 2 step to help with launching. I’ve heard arguments of 2 steps being deemed slightly pointless in an auto, just get a trans brake at that point, not being needed in an auto, just use the brakes, etc. Looking for clarification on that. If I did get a 2 step, would I set the rev limiter to match or fall under the stall in the converter?
Old Sep 14, 2024 | 10:17 AM
This should be in the nitrous forum...
Old Sep 14, 2024 | 10:36 AM
66OldsLS's Avatar
What does 2 step have to do with nitrous?
Old Sep 14, 2024 | 01:07 PM
Sorry. I was thinking of a 2 step nitrous shot, though I might have that mixed up with something else....
Carry on with my apologies...
Old Sep 14, 2024 | 01:17 PM
66OldsLS's Avatar
All good, been there done that. I’m just looking for an explanation of what I’ve heard about 2 step with autos as I’ve listed above. And if I should install a 2 step.
Old Sep 14, 2024 | 01:19 PM
The 2 step you mention is new to me. Could you briefly explain what it is?
Old Sep 14, 2024 | 01:24 PM
66OldsLS's Avatar
The MSD 2 step? Cuts ignition, different rev limiter, helps build boost, helps with launching.
https://www.summitracing.com/parts/m...xoCInMQAvD_BwE
Old Sep 14, 2024 | 02:17 PM
Ooookaaay! NOW I know. I hit the Summit link you provided, and the light went on!
Thank you very much!
Old Sep 14, 2024 | 03:11 PM
66OldsLS's Avatar
yeah, I’m building this motor to make around 700 HP, 6000 RPM, 10 PSI, fun little street car. Will take it to the track every once in a while. So should I do a 2 step?
Old Sep 14, 2024 | 03:59 PM
IF it will help with a good launch AND possibly be easier on the parts, I would give it a go.
Sounds like a useful tool for more effective strip performance.
BUT, I'm no expert on such matters....
Choose wisely, grasshopper.....
Old Sep 14, 2024 | 04:06 PM
66OldsLS's Avatar
Sounds good to me. I may not be the most knowledgeable on the 2 step right now and how it functions but over time I will, by that I mean when I get it running
