Flexplate Bushings or Shims??
Old Nov 19, 2024 | 10:50 PM
Fffrank's Avatar
Default Flexplate Bushings or Shims??
Rebuilding a junkyard LQ4 and went to install stock flexplate and found these strange bushings/shims around the mounting holes. I was confused to find them threaded so went to chase with a tap and it immediately came out of this hole. Doesn't seem necessary but I wanted to check first?
You can see one hole with it knocked out and the other where it still remains?
Old Nov 23, 2024 | 04:45 PM
the_merv's Avatar
Veteran: Air Force
Faint thread because of the bolts that were in there. Put it back in and bolt it up.
