Keep burning spark plug wires.
- ACCEL 9001CK: Features 90-degree black ceramic boots, suitable for custom routing.
- ACCEL 9002C: Comes with 135-degree white ceramic boots, offering flexibility in tight spaces
I had sleeves on my wires previously… the dyno guy who found the burned wires (only noticeable miss under full load) said the sleeves were useless, they just hide where the wires burn through.
May look horrible. But you can run a length of bailing wire down the plug wire. Then wrap layers and layers of tin foil over it. Then the plug wire holds what ever shape you put it in with tons of heat protection. Spray paint it black or run a sleeve over it and its not so bad.
So Accel ceramic, no heat boots? I saw them today, as it would be really easy I was thinking Heatshield products boots..thoughts?? The headers I have look like pretzels, CYL 4,6,3,5 are real tight
Just get a cut to length kit and come up from the bottom?
Engine masters did an episode where they beat the snot out of a header with a hammer over and over. At the end it looked like someone ran it over with a truck. It lost zero power compared to an un-dented manifold. Ya gotta do what ya gotta do! lol
14” Coil harness extensions are dirt cheap on ebay. I used a set to put the coils at the frame rails. Ran the wires up from the bottom as well. Worked really well and was pretty cheap/easy.
Sitting on the frame.
LS Remote Mount Coil Relocation Brackets D585 LSX LS LQ4 LQ9 Swap Billet | 551562 - ICT Billet
