Cable Throttle Body Help - Spring
Old Dec 23, 2025 | 02:51 PM
trever20's Avatar
Default Cable Throttle Body Help - Spring
Working on my intake/TB setup and am using a TBSS intake with a 3 bolt oem cable TB (with an adapter). I have the cable hooked up properly and have one fairly minimal bend, but otherwise the cable run is free of any sharp turns, obstructions, kinks, etc. The pedal/throttle blade operates fine, but it just does not return as quickly as I would like. I've tried to find stiffer springs, or find a way to add an aditional one and am not having much luck. Has anyone ran into this issue? It seems like I could fab up a bracket easily enough to hook the spring to the engine side, but I'm not sure how I could hook the other end to the TB. See photo attached.
TB markup.pdf
Last resort is to convert to DBW, but at this point I would like to avoid that. Let me know your thoughts. Thanks!
Old Dec 23, 2025 | 02:52 PM
trever20's Avatar
Old Dec 23, 2025 | 03:38 PM
LS1 TJ's Avatar
Hard to tell from just the side pic but are you pulling from an angle side to side? Also the down angle seems a bit much.
Can you fab a new bracket that lowers cable bracket and puts it more in line left to right? Might mean a new throttle cable from Lokar?
Pic of my Wrangler with a LS6 swap. LS6 intake. I had to fab a throttle cable bracket for my project. Zero problems spring wise.
Old Dec 23, 2025 | 03:57 PM
trever20's Avatar
Thanks for the quick response. The bracket is a standard TBSS cable conversion bracket that I purchased and I believe people commonly use this without issue. I don't believe the downward angle is the issue (I could be wrong), and it is able to pull all the way from 0-100% without issue, just the spring-back doesn't feel very confident. As far as side to side, it is in perfect alignment - may be hard to tell from the photo.
