Anyone seen these problems?
Old Sep 2, 2004 | 05:37 PM
  #81
John98LS1's Avatar
dude we need to figure what the hell is wrong... its weird when ever i get the probleam ill run the car for like a 1 min then ill turn it off and turn it back on and everything will be fine???
Old Sep 2, 2004 | 07:59 PM
  #82
jlrz28's Avatar
10 Second Fun Car
Ive been using Chevron gas for 2 weeks 4-5 fillups. So far I havent had any problems, I cant even get the car to mess up any more.
Old Sep 10, 2004 | 04:40 PM
  #83
John98LS1's Avatar
its the gas!!!!!!!!
Old Sep 10, 2004 | 11:28 PM
  #84
jlrz28's Avatar
10 Second Fun Car
Originally Posted by coolguy
its the gas!!!!!!!!
Thats what im thinking!
Old Sep 12, 2004 | 02:59 PM
  #85
pontiac's Avatar
I have tried lots of different gas and it does not seam to be a certin kind but wee do need to figure it out and has any body ran there car with this problem does it affect the tract times or just crusing.
Old Sep 12, 2004 | 07:36 PM
  #86
99PontTA's Avatar
this is a long shot but i've read about water in the gas fouling the fuel rail with rust.....also if water was sitting in the fuel rail it might cause a problem ..maybe try a little dry gas or i use the isopropical alcohol in the tank ..it will grab any water and let it mix with the fuel so it moves out of the system........i'm not positive but i think most gas companies add an additive to all fuels to take care condensation problems in underground tanks in winter time...but i don't think they do in the summer.
Old Sep 16, 2004 | 01:08 PM
  #87
John98LS1's Avatar
do the dry gas thing.. it works... did for me!!!
Old Sep 16, 2004 | 05:01 PM
  #88
jlrz28's Avatar
10 Second Fun Car
What is dry gas??
Old Sep 16, 2004 | 05:52 PM
  #89
John98LS1's Avatar
google it!
Old Sep 16, 2004 | 06:52 PM
  #90
jlrz28's Avatar
10 Second Fun Car
Maybe this is why my Chevron with Techron gas fixed my problem!!!
http://www.ask.co.uk/ix.asp?q=dry+ga...%2Ehtml&adurl=
Old Sep 17, 2004 | 12:29 PM
  #91
John98LS1's Avatar
i used the ipa based one
Old Sep 17, 2004 | 05:48 PM
  #92
pontiac's Avatar
ok where can i get it and has it worked for everyone that has tried it. and how much $$$$$$$$$$$$$
Old Sep 18, 2004 | 07:49 AM
  #93
jlrz28's Avatar
10 Second Fun Car
You can go to a parts store and get heat. As far a I understand the Techron is better for fuel injection motors. You can buy techron also in a bottle. I have simply just been filling up with Cheveron gas which has Techron in it! I have heard also Methanol will work too.
Old Sep 18, 2004 | 08:27 PM
  #94
John98LS1's Avatar
chevron gas is whats been hurting the guys cars around my side of town. 1960 and 290
Old Sep 20, 2004 | 10:19 AM
  #95
pontiac's Avatar
Has it work for alot of people or just the two of you???? anybody??????????
Old Sep 20, 2004 | 11:37 PM
  #96
XpEdItIoUs's Avatar
I had the same problem but i stoped using shell and i now use 76 gas 91 octane and mix it with 100 ocatane sometimes my car runs better now and i also use redline fuel system cleaner.
Old Sep 21, 2004 | 11:40 AM
  #97
Juiced's Avatar
i agree first do the fule filter then if that's a no go change the 02
Old Nov 21, 2004 | 11:35 PM
  #98
John98LS1's Avatar
still have the problaem
Old Nov 22, 2004 | 04:07 PM
  #99
jase94's Avatar
its your fuel injectors!! my car was doing the EXACT same thing, and i found out only 6 were spraying. just change the blocked ones and clean the rest, problem solved.
Old Nov 28, 2004 | 03:33 PM
  #100
John98LS1's Avatar
nope.. its not my injectors
