Anyone seen these problems?
Old Aug 16, 2004 | 07:07 PM
  #41
John98LS1's Avatar
man im going to change the fuel filter and see whats up.
Old Aug 16, 2004 | 09:57 PM
  #42
jlrz28's Avatar
10 Second Fun Car
Yeah Im going to look for a set of injectors then heck while Im there go ahead and put a Ls6 intake on it! Sounds like a good reason to put one on since Ill be halfway there!
Old Aug 18, 2004 | 08:58 AM
  #43
stephenz99z's Avatar
one of my pcv valves hose going behind the throttle body not to long ago was pretty much toast it was coroded and falling apart which made my car run like crap too. i replaced the hose and valve and now i wander if peices of that hose went throuhg and is now tearing at my internals or cloging up something. i dont know i just feel i should drive my car into a pole
Old Aug 18, 2004 | 10:26 AM
  #44
ILLWS6's Avatar
I've been having the same exact problem too. I put a bottle of injector cleaner in and burned all of the nasty gas off, then filled up at a different station. This was just last night so it may be too soon to tell, but it seems to have cleared up. I didn't think it was the gas either but I couldn't find anything else wrong. I'll keep you guys posted on what happens.
Old Aug 18, 2004 | 10:29 AM
  #45
ILLWS6's Avatar
COOLGUY-Definetely change the fuel filter and run some injector cleaner through there.
Old Aug 19, 2004 | 05:50 PM
  #46
John98LS1's Avatar
thats what im going to try bro
Old Aug 19, 2004 | 06:19 PM
  #47
Tranzaman00's Avatar
Dude, Please let me know what you find I'm having the exact same problem. Same cylinder #6 misfire I have changed plugs wires fuel filter ran lucas injector cleaner swapped coil pack with #4 still came up #6 misfire I was hoping it was the coil pack but it didn't fallow to #4 when I scanned it again.
My post is https://ls1tech.com/forums/generation-iii-internal-engine/206004-somebody-anybody-please-help.html
Old Aug 20, 2004 | 10:10 AM
  #48
ILLWS6's Avatar
Well guys it's still doing it but not nearly as much. I'm not really sure what my next step is yet. I'm getting a bit frustrated. If any of you find anything out please post it here so the rest of us can give it a shot.
I've noticed on the three ls1 based boards that I frequent there's alot of people getting this lately. Noone that I know of has been able to figure it out yet. Good luck all.
Old Aug 20, 2004 | 11:42 AM
  #49
kenkaru's Avatar
The more gas I have in the tank, the less it happens I've noticed. I still don't understand why it would happen with 1/2 tank though. I'm gonna check out all of my fuel lines, starting at the gas tank.
Old Aug 22, 2004 | 05:15 PM
  #50
jlrz28's Avatar
10 Second Fun Car
Yeah guys Im going to go ahead and order the injectors and change them in a week or 2. I have seen 2002ss camaro having bad injectors. Mine only causing a problem after they have been heat soaked and the system is all pressured up. When the car is completetly cooled down it works fine.
Old Aug 24, 2004 | 10:21 AM
  #51
Z28-CTYHNTR's Avatar
Let me know if replacing the injectors works, Im willing to try just about anything at this point.
Old Aug 28, 2004 | 01:54 PM
  #52
John98LS1's Avatar
man i think its the gas were gettin. im going to look into this more guys
Old Aug 28, 2004 | 06:57 PM
  #53
jlrz28's Avatar
10 Second Fun Car
Yeah sorry Im still waiting on my Ls6 intake from SLP otherwise Id already have the injectors on! I should get it this week. Would this possibly be a fuel pump problem? How many miles does everyones car have on it. Mines kissing 75,xxx
Old Aug 28, 2004 | 07:47 PM
  #54
ninobrn99's Avatar
is the gas tank run by vaccum? has anyone called the dealership to find out if there is a TECHNICAL SERVICE BULLETIN for a similar problem?
Old Aug 29, 2004 | 12:34 PM
  #55
jlrz28's Avatar
10 Second Fun Car
That might be something to look into. How would you go about doing this?
Old Aug 29, 2004 | 10:40 PM
  #56
ninobrn99's Avatar
just call them up and ask to speak to the service dept. tell them the problem your having and ask if they can find out if the is a TSB on it. I did for my m6 because I had problems putting my car in reverse..that and I have a few friends that work at the dealership
Old Aug 29, 2004 | 10:55 PM
  #57
CAT3's Avatar
Restricted User
check plugs/wires too please.
Good luck
Charlie
Old Aug 29, 2004 | 11:00 PM
  #58
ninobrn99's Avatar
Good luck
Charlie
good idea...make sure there isnt any carbon build up on the plugs...
Old Aug 29, 2004 | 11:02 PM
  #59
me and the guy that started this post are having the same probs. we/I have replaced plugs,wires, coilpacks,new fuel rails w/injectors,fuel filters everything now what.
Old Aug 29, 2004 | 11:33 PM
  #60
ninobrn99's Avatar
did you already check for vaccum leaks as well? has it been scanned for codes? no bad sensors or anything right?
