Solid Motor Mounts
Old Aug 22, 2004 | 01:49 PM
Mr Powell's Avatar
Default Solid Motor Mounts
Who has them, who sells them... Benefits over stockers.. Let me know..
Old Aug 22, 2004 | 06:29 PM
jrp's Avatar
jrp
SN95 Director
IIRC madman stopped selling his, i know Spohn still sells them. thats what im going with.
Old Aug 22, 2004 | 08:23 PM
WILWAXU's Avatar
Have you tried the poly mounts?
Old Aug 22, 2004 | 09:19 PM
D Rock's Avatar
What benefits will I get with these over the stockers?
Old Aug 22, 2004 | 09:28 PM
jrp's Avatar
jrp
SN95 Director
more stabilty of the engine in the bay. wont move around or flex and cause issues like header or Y pipe banging. cons are more vibrations and rattles. with solid mounts you get a 10-12lbs weight savings. with poly mounts you still have to use the cast iron pedistule (sp).
Old Aug 22, 2004 | 10:11 PM
LS1S10's Avatar
Thought i read somewhere that solid mounts or poly mounts weren't good for the LS1 because the engine is more likely to pick up vibrations from the chassis and sense it as knock. Seems logical to me that rubber mounts would absorb more vibration and is less likely to cause a faulty knock reading. I know personally i've driven down the road in my Z71 with my Predator hooked up checking out real-time and went over a couple of mild bumps and got up to 12 degrees knock retard with just stock mounts.
Old Aug 22, 2004 | 10:53 PM
jrp's Avatar
jrp
SN95 Director
some people have some people havent, just one of those things :dunno:. there isnt a unanimous consensus one way or another.
