Cut-out/Y vs. True Duals
Old Aug 29, 2004 | 11:36 AM
Simp's Avatar
Default Cut-out/Y vs. True Duals
First off I will say that I love the sound/performance of my true duals. But I have always wondered how a dyno comparisson of an open cutout y-pipe setup would compare to true duals. I've heard that the peak HP numbers are similar, but the duals make better power under the curve. Anyone have back to back dyno numbers?
The reason that I'm asking is I'm planning on lowering my car soon and am extremely worried about clearance issues with my 3" TD's. I live in Atlanta, with some of the worst roads ever, and have already scraped the duals a few times on stock ride height. I'm thinking I need to go to a cut-out/Y/cat back system or perhaps 2.5" duals.
Old Aug 29, 2004 | 11:44 AM
mrr23's Avatar
yes i did back to back runs. but this was over stock exhaust. gained 11/13. but at the track, did nothing for the 1/4 mile. but did change what happened in the quarter. it moved the power curve upwards. look at the 60ft and 1/4 mph.
cutout closed ----- open
60ft - 1.987 ------ 2.074
1/8 - 7.902 ------- 7.912
mph - 93.20 ------ 93.97
1/4 - 12.102 ----- 12.080
mph - 117.12 ---- 118.06
Old Aug 29, 2004 | 12:13 PM
Full-Force's Avatar
does that formula have nitrous on it?
Old Aug 29, 2004 | 12:48 PM
LS1LT1's Avatar
Thumbs up
So this was just a Y pipe with a cut out closed versus open right? No duals involved I assume?
I wouldn't exactly call that nothing in the 1/4 mile dude, you gained some nice trap speed uncapped.
Old Aug 29, 2004 | 01:10 PM
Z28Venom's Avatar
My first setup was the Pacesetter ORY with dual cutouts. Lemme tell ya, that thing took away alot clearance.
I'll have pics this afternoon of 2.5" TD's lowered with the Eibach Prokit..
Old Aug 30, 2004 | 07:51 AM
Simp's Avatar
anyone else?
Old Aug 30, 2004 | 07:08 PM
mrr23's Avatar
yes. 200 hp to be exact.
Old Aug 30, 2004 | 07:11 PM
mrr23's Avatar
all stock exhaust http://www.stealthram.com/qtpcutout.html let me clarify. did nothing for ET. but lost 60ft to gain 1/4 mph.
Old Aug 30, 2004 | 08:22 PM
Simp's Avatar
anyone know anything else about the topic?
Old Aug 30, 2004 | 10:43 PM
Jorday's Avatar
When I switched from a y pipe to true duals I only gained approx .1 ET and a mph or two.
Old Aug 31, 2004 | 09:54 AM
Simp's Avatar
Was that with an open cutout or closed?
Old Aug 31, 2004 | 12:02 PM
Lucian's Avatar
do you think that the longer ft times would be due to a traction problem. So possibly if you were able to hook the tires up a little more then you would have a little better time. Just my opinion from looking at the numbers w/out seeing the actual track run
Old Aug 31, 2004 | 12:04 PM
Lucian's Avatar
what setup did you have before and after (i.e. cats, headers, type of y, type of catback)
that all could play an important role in the gain from one to the other
Old Aug 31, 2004 | 07:40 PM
Jorday's Avatar
I had macs with off road pipe and an SLP dual/dual catback with a cutout,
I switched to thunder LT headers with an all 3 inch true dual system with x pipe, bullet mufflers and turndowns.
I didn't use cats on either setup.
Old Sep 1, 2004 | 12:55 AM
LS1LT1's Avatar
Lightbulb
Yes that could be a strong possibility as well, more power often equals less traction of course.
Old Sep 1, 2004 | 01:32 AM
2MuchRiceMakesMeSick's Avatar
Who has ran both cutouts with y AND true duals in two different setups? Which gives you the lowest times? I have true duals and im thinking to switching to cutouts with y pipe. Will I gain any time/power?
Old Sep 1, 2004 | 09:55 PM
2002$$'s Avatar
no a y-pipe doesnt net you very much flow....the x-pipe however gives more velocity,therefore yielding more torque(under-the-curve)which is something you always want. duals flow more freely,and ive heard that a crossflow muffler;especially Slowmaster,only support up to 350-horse.....maybe your making more but couldnt get it through that muffler....TD's ALL THE WAY! plus when i open my cut-out's i LOSE power! it sucks;i guess my exhaust is already free-flowing enough,that the c/o doesnt gain me any flow.it saps the low-end hard and doesnt really yield you much more top-end...sounds sick,though.
Old Sep 1, 2004 | 11:45 PM
WiseguyZ28's Avatar
Can u open electric cutouts in the middle of the run? How bout trying to get the best of both worlds. Start out with it closed and then open it bout halfway down the track. I have FLP's w/ory and a gmmg but am thinkin of gettin the TexasSpeed True Duals but here's the question, if i get a cutout then would i be making the same power as true duals or something minimal or would it be a good difference.
Old Sep 2, 2004 | 12:43 AM
2002$$'s Avatar
i think w/ a full cat-back;youll make a little more power,BUT if you want to get a lot of torque-under-the-curve....go with the TD's they make a lot more power.IMO.
Old Sep 2, 2004 | 01:23 PM
mrr23's Avatar
zero traction problems. burnout so good that smoke was coming up through the center console. i come out on the motor. then at 2000 rpm hit the bottle. i made about 5 runs that day with it open. then i closed it, and voila the 60ft came back. there i a video of one of my runs aver at need2speed.com bradenton track day. 5 minutes long at 4 minutes is me and a pewter TA going at it. you'll see the burnout.
