ASP pulley installed -- charging issues
Car is having charging issues.
Voltage output only 12.8V at the battery using a fluke meter.
Disconnected the ground cable, car died immediately.
SES Light -- P1637 Generator L Circuit
I'm not sure if I have a bad alternator, or if I need to purchase the alternator pulley to go along with the ASP Pulley.
Has anyone else had this problem? Please chime in.
btw. this test is not recommended by any manufacture!
So the ground cable method doesn't prove anything with the newer cars?
I have no clue where to go next..
I'm having issues when I attempt to take off, I get a bit of knocking. The car seems to be bogging on take-off.
I'm ashamed to say, it was all my fault. I guess we learn from our mistakes, I definitely won't make this one again. Whenever I solder something in the future. I'm using heat shrink.
Problem: P0200 and P1637 code --
- The car would also kill my new Optima battery every other day.
- Would completely stutter and knock and ping and fall on it's face at take off.
- Sounded like ***
See, what had happened was:
-Be warned: Be extremely careful when you do the !Wire mod. Because of a crappy isolator, 3 of the wires shorted together. Causing the injector 2 fuse to blow in the engine bay power block. Entire passenger side of the engine was without power. It also fried one of my fan control relays. So after getting the wiring taken care of and replacing the fuse and relay.
