StreetPro Exhaust Cutout *Video
Old 09-05-2004, 09:57 PM
Fiery Features Director
Zangel's Avatar
Default StreetPro Exhaust Cutout *Video
Today we finished the install of the StreetPro street/strip cutout. IMO this cutout is the highest quality cutout on the market. I shouldn't have any problems with this one (unlike the others)! I showed the difference with the cutout open and closed in the video. With the cutout closed, the exhaust runs through a Borla Catback w/ a plate that has 3 1/4" drilled holes. The video is attached.
Right click, save as...
http://www.htownracing.com/Video/Cutout.wmv
Thanks StreetPro!
Old 09-05-2004, 10:30 PM
Full-Force's Avatar
awesome ... what stall does that car have? .... sounds good
Old 09-05-2004, 10:36 PM
Zangel's Avatar
Thanks! The car has a 3200 Vigilante Converter. I plan on putting the car on a dyno soon (before I put the turbo on). I will get some numbers with the cutout open and closed.
Old 09-05-2004, 11:18 PM
MikeG's Avatar
Nice work on the alarms!
(The cutout looks/sounds good too)
Old 09-06-2004, 12:38 AM
CaptUSA's Avatar
Nicely done. Thanks.
Old 09-06-2004, 01:00 AM
Z28Venom's Avatar
First time seeing one of those in action. It's definitely a need little setup.. I'll more than likely run one of those when I switch back over to the stock catback.
Sweet video also..
Old 09-06-2004, 03:09 AM
Dope's Avatar
What is your idle set at? Seems super high (900+), can't even hear any lope.
To be quite honest I could barely tell a difference between the vids. Car sounds awesome either way.
Dope
Old 09-06-2004, 10:26 AM
Zangel's Avatar
Dope
The idle is set high. The reason you don't hear much lope is because the motor is a low comp. built 6.0L with a small (224/224 112) cam. I am in the process of switching cams and adding a turbo. The idle is set high so the car will actually stay running. I notice a huge difference when opening the cutout (and so do my neighbors) The reason you couldn't tell much of a difference is because the camera was behind the car at all times. One exits under the car and the other behind the car. There also wouldn't be a HUGE difference because I decided not to close off my exhaust. I did not like the sound of a completely closed Borla Plate. I had to go with a plate that was about 50% open. If I were to completely close off the Borla, it would be a night and day difference with the cutout open and closed.
Old 09-17-2004, 10:45 PM
FenixSS's Avatar
What size cutout did you get from Streetpro? Are you using your stock Y or an Off Road Y?
I was thinking about getting QTP Headers with their Electric Cutout Y, but due to cost thinking about a cheaper set of headers and offroad y and getting streetpros as the dual cutouts.
Old 09-18-2004, 12:59 AM
Zangel's Avatar
The cutout is 3" and I have an off road y-pipe with Jet Hot headers.
