Is this a ls6 intake?
Old Sep 15, 2004 | 11:47 AM
ninobrn99's Avatar
i have a few ?'s about the coolant lines...on ls1howto they use 2 lines and no plugs..if i get the coolant line and plugs, where do they go and what do they look like? the wires under the manifold, do they stay under or do i move them behind the manifold? also what are the part #s for them?
Old Sep 15, 2004 | 09:59 PM
WILWAXU's Avatar
Coolant plugs go on the rear holes on the heads. Front holes get the coolant cross over pipe. Wires stay.
These threads might help.
https://ls1tech.com/forums/generation-iii-external-engine/202289-ls6-intake-help-please.html
https://ls1tech.com/forums/generation-iii-external-engine/209212-ls1-ls6-intake-coolant-lines-plugs-where-does-go.html
https://ls1tech.com/forums/generation-iii-external-engine/47299-need-part-s-ls6-coolent-pipe-plugs.html
Old Sep 16, 2004 | 11:43 AM
Keenov's Avatar
The part numbers are on LS1HowTo
Old Sep 16, 2004 | 11:55 AM
ninobrn99's Avatar
thanks..i dont know what i did with the part # the one i thought was it turned out to be a flywheel..my bad
Old Sep 16, 2004 | 01:32 PM
buschman's Avatar
I can't believe someone paid $255 for a painted LS1 Intake. It's a shame, cause if you read his description the only really false line is "It is the newer style non-egr manifold which should flow better." Technically a non-egr LS1 intake might flow better(less disruption), but it's not a newer style. That ad is worded to deceive, but it does say LS1 intake in the title. You can't really blame the seller for any wrong doing. That being said, I don't think it's the most ethical ad ever.
Mike
Old Sep 16, 2004 | 01:40 PM
ninobrn99's Avatar
what rims are on that camaro? the yellow one..
