leaking AIR help needed
Old Sep 13, 2004 | 02:34 PM
slik98z's Avatar
Default leaking AIR help needed
I found out today that my AIR connection on the drivers side is leaking pretty bad. i have restrictor plates cause i cannot afford to get a tune to get the light shut off so these will have to do for atleast a while longer. but its leaking pretty damn good.
Could a leak such as this echo off my valve covers and sound like its coming fro my valve train? cause i have this really nasty squeeking almost rattling sound coming from the drivers side of my engine compartment and when i changed out my cam, springs, and retainers nothing changed.
its not a fluttering sound, but more a squeeking/ticking/rattling sound.
how do i stop this leak? will hi-temp rtv sealant work ?
Travis
Old Sep 13, 2004 | 02:36 PM
codster11's Avatar
I put some gasket maker/sealer on my block off plates when i removed the air/egr systems from my car, works great no leaks, hasnt been a problem yet, try that, should work just fine.
cody
slik98z's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/215145-squeeky-sound-coming-valve-train.html
this is an attempt to link my post from the internal engine section
does this sound like its an exhaust leak, explanation within
