Why do we hear detonation?
Old Sep 19, 2004 | 05:51 AM
Patman's Avatar
Default Why do we hear detonation?
This is something that has bothered me for many years now. If the LS1s come with a knock sensor, how come so many people have heard their engines detonate? Is it that the system cannot react fast enough?
Old Sep 19, 2004 | 08:28 AM
Cstick's Avatar
I am not positive but I do not think the computer can take enough timing out to get rid of the pinging. I am going to run a 160 thermostat soon. Cooler temps should cure some of that and let the engine have more timing!!
Old Sep 19, 2004 | 11:03 AM
jimmyblue's Avatar
Moderator
Yes, knock sensor is only "after the fact", has a limited
rate of timing pull and a limited amount too. The rate &
pullback limit vary by RPM. Tuning to suppress the
cause is best, KR is like the cop who shows up after
the murder has been committed.
Old Sep 19, 2004 | 12:42 PM
Z28Venom's Avatar
I like the way you broke that down. Good info.
Old Sep 19, 2004 | 07:05 PM
Patman's Avatar
I'm definitely going to have to get mine retuned with a less aggressive timing curve then (I had ARE dyno tune it for me and I think they've got it at about 28-30 degrees of timing). I don't get a huge amount of detonation, but I don't like hearing anything at any time, under any circumstances, especially if it's only 70 degrees outside.
Old Sep 27, 2004 | 11:43 PM
WS6freak's Avatar
In a normal non-pinging engine, the spark plug fires at the desired time and initiates a spherical flame that moves across the combustion chamber consuming the air/fuel mixture as it goes. This flame increases the temperature and pressure in the cylinder and creates your power. When the combustion chamber temperatures get high enough, it is possible for the air/fuel mixture to spontaneously combust (pre-ignition). This is what happens when a car "diesels" on runs on after the ignition is turned off. Commonly the source of the ignition is from carbon deposits or simply a sharp edge on the piston or head surface.
When both pre-ignition and regular ignition occur simultaneously, you get two flame fronts moving towards each other. When they meet, they extinguish each other with a loud pop. That pop is the ping. This effect is similar to turning off the acetylene on an oxy/acetelene torch. The ping is not harmful. But it is an indication that there is something amiss, something that may be silently damaging you engine.
One source is excessive carbon buildup. That means nothing is wrong and the engine simply needs a good cleaning, ON THE INSIDE. The reason for the excessive carbon could be due to an oil consumption problem, either leaky valve seals or worn piston rings. Either way, the head needs to be removed to solve the root cause, the can be decarboned at the same time. An engine is normally good at burning away carbon on it's own. The problem could also be due to mal-adjusted carbs or a dirty air filter causing the engine to run way to rich. Again, that is a problem that needs correcting and a 1/2 bottle of Techron engine deposit cleaner will quiet it right up. In no case does the pinging from carbon cause engine damage.
The other cause of pinging is excessive cylinder temps. As the temps rise, the sharp edges of the piston will ignite the mixture. The excessive temperature will also start to melt the piston. Again this could be due to a number of situations. One case would be a dirty air cooled engine or a water cooled engine with some problem with the cooling system. The other possibly is that engine was designed to run that hot (like a race engine) and simply needs higher octane. This will in time cause engine damage, but it is again and indication of a problem. If the engine is dirty, higher octane will cause the pinging to go away, but it is still running too hot.
Contrary to what the gasoline companies advertise, engines never need to change octane. If a new engine is happy with 87 and at 40,000 miles starting pinging, that means is time for some maintenance, not higher octane. Many european cars and bikes need higher octane because of their better fuels. The US has the "worst" fuel in the world. Germany starts the fuel grades at 96 octane, the their engines are designed to need it. Now, many foreign manufacturers "de-tune" their engines to run on our 87 octane gas. If your engine needed 89 or 92 octane new, then that is what you must run. If it didn't need 92 new, and does now, look for a problem.
Now on the subject of a properly tuned engine pinging. Yes, they should ping, a little under certain conditions. Engineering is a field of compromise. You want the most power, the best fuel economy, the cleanest emissions, and the longest longevity out of any engine. But each of these conditions requires different tuning, generally opposite from each other.
An engine needs to be tuned to operate at a sweet spot that is the compromise of all requirements.
As I said earlier, pinging can be the result of high combustion temps, and this is the type you would expect to occur. High temps are caused by a combination of lean fuel and advanced timing. Lean fuel produces higher combustion temps and hence more power. It also produces higher emissions and potential engine damage.
When the engine is under sever load and a low RPM (like climbing a steep hill in top gear) then engine temperatures rise and will begin to ping. That is normal. That is desired. Yes, you are damaging the engine and melting the piston. (More on that later). That means that you have crossed the line are no longer is that compromise zone. That is good because engines are not meant to be operated in that fashion. PINGING MEANS IT IS TIME TO DOWNSHIFT.
Engines, particularly motorcycle engines, make their power in the upper 1/3 of the RPM range. If you are under sever load, you want the tachometer up near red line. That is where the engine was designed to run and it is by far the easiest on the motor. When you are lugging an engine, the oil pressure drops and the piston rods begin hammering against the crank shaft because there is no longer a high-pressure film of oil to prevent it. Likewise, the crankshaft in turn hammers against the block (or case). In either case, the damage you are doing to the bearings is far worse than the slight amount of aluminum being burned away. If you switch to a higher octane fuel to prevent the pinging, you may not realize you are destroying your bearings.
You could also retard your timing or richen the carbs to prevent pinging under severe load on whatever octane gas you desire. But again, this will mask the bearing damage you are doing. It also moves the threshold of that "sweet spot" downward. Now you will not have pinging under sever load, but you will also not have complete combustion under normal conditions (such as cruising), and that can lead to poor fuel economy and excessive carbon deposits.
In a nutshell, the engine should ping if properly adjusted, under low RPM, severe load conditions. Next, you should use your transmission to avoid those conditions.
