What do i need for pulleys?
Old Sep 19, 2004 | 01:10 PM
01sunsetSS's Avatar
Default What do i need for pulleys?
Im going to be getting an Asp pulley very soon and I did a search and im still confused about what i need. i have no aftermarket stereo system or subs that require a lot of power. What should i get? Do I need the crank and alternator pulleys or just a crank pulley? Im a newb so I have no idea what to get.
Old Sep 19, 2004 | 01:17 PM
Z28Venom's Avatar
www.thunderracing.com
You're going to need:
ASP Pulley
Shorter Accessories Belt
Shorter A/C Belt
The Thunder site breaks it down for ya.
Old Sep 19, 2004 | 01:21 PM
01sunsetSS's Avatar
Ok so i need
- Belt for AC Pulley, 1998-2002 LS1 F-body
-ASP Harmonic Balancer Crank Pulley, SFI 18.1 Approved, 1998-2002 LS1 F-body
-Accessory Belt for ASP Crank & ASP Underdrive Alternator Pulleys
is that right?
Old Sep 19, 2004 | 01:55 PM
Z28Venom's Avatar
Originally Posted by 01sunsetSS
Ok so i need
is that right?
ASP Pulley
Belt for A/C
Accessory belt for ASP Crank pulley only.. (since you're not buying the alternator pulley)
Old Sep 19, 2004 | 01:59 PM
01sunsetSS's Avatar
Ok i got it. Thanks alot for the help. Sweet ride by the way
Old Sep 20, 2004 | 01:37 AM
BLASTER's Avatar
I am looking to get an ASP too. Why won't we need an alternator pulley too? Will that provide any more gain if I went with a underdrive alternator pulley also?
Old Sep 20, 2004 | 03:02 PM
ty_ty13's Avatar
7 Second Club
Default New Bolt
SPEND A LITTLE CASH AND GET THE ARP BALANCER BOLT....in the long run youll be happy
Old Sep 20, 2004 | 03:38 PM
99Hugger's Avatar
Ok so i need
is that right?
Your going to need a new pulley center bolt as well, TR has them. The bolts are one use only, you can't re-use the one you take off.
Old Sep 20, 2004 | 04:00 PM
ty_ty13's Avatar
7 Second Club
Default Arp Balancer Bolt
ARP BALANCER BOLT use these as many times as you want...done right the first time=
Old Sep 20, 2004 | 05:05 PM
99Hugger's Avatar
Originally Posted by NoseUpChromeDown
Most pulley sets come with a new bolt for that reason
Not if ya buy a used one. He didn't specify...
