asp crank pulley owners inside-->
Old Oct 12, 2004 | 07:51 PM
BLASTER's Avatar
I have one waiting to install but I am concerned becasue I don't have the appropriate install tool and don't want to rip the crank threads. How did you guys install yours?
Old Oct 12, 2004 | 09:18 PM
chpmnsws6's Avatar
install or take off stocker? to take it off, go to harbor freight and get a puller or go to A-zone and rent one free of charge. to put one on- i held the stock pulley infront of it and hit it with a BHF lightly a few times... then threaded the stock pulley bolt in and hit it with the impact till i got scared, then did it about 10 more seconds. pulled the bolt out, put the new bolt in and set it at 37ft pound then turned it 120 degrees :thumb
Old Oct 12, 2004 | 09:30 PM
BLASTER's Avatar
Install.....I have the pulley puller. Weren't you afaid of ripping or striping the crank threads?
Old Oct 13, 2004 | 01:19 PM
ninobrn99's Avatar
hey A-Bomb its cool, I think some of the "older" guys here will back me up besides, you dont need a pully...you need more than that to beat me how about a TNT kit? maybe that will help you out a bit more than a pully j/k cuz
Old Oct 13, 2004 | 01:33 PM
imos-ss 01's Avatar
You have to buy a 3-jaw puller to get the stocker off...once you've unthreaded the bolt keep it there with about 3 full threads, place the 3 jaw puller in the 3 slots in the stock pulley. you'll see how this works obviously. I used a sledge hammer and a 2x6 to bang on the asp. Thread the asp with the old bolt until you're very close to point of origin. Replace bolt and thread until needed. 250 ft lb..... good luck man...
Old Oct 13, 2004 | 05:04 PM
A-Bomb's Avatar
you WILL get yours in DUE time, young buck.
Old Oct 13, 2004 | 05:08 PM
ninobrn99's Avatar
thank u
Old Oct 13, 2004 | 10:27 PM
chpmnsws6's Avatar
nope, after i got 3-4 threads in i felt safe enough with it...... i also turned the impact down so it was a slow process
Old Oct 19, 2004 | 09:05 PM
2w0s060's Avatar
I am assuming the ASP crank pulley is supplied with a new belt, or not?
Old Oct 19, 2004 | 10:12 PM
chpmnsws6's Avatar
nope, but a belt is cheap
Old Oct 20, 2004 | 03:20 AM
LS1LT1's Avatar
Lightbulb
Two new belts needed actually.
Old Oct 20, 2004 | 03:37 AM
  #32
2MuchRiceMakesMeSick's Avatar
Sometimes you can find packages, i LGM sells a package. Thats where I got mine. Comes with pully, red line syn ps fluid, bolt, and two belts.
Old Oct 20, 2004 | 03:51 PM
  #33
chpmnsws6's Avatar
nope, just one
Old Oct 20, 2004 | 04:41 PM
  #34
Hardtop00SS's Avatar
I've heard of the ASP causing false knock, is this true?
Old Oct 21, 2004 | 12:54 AM
  #35
LS1LT1's Avatar
nope, just one
No A/C in your car I take it?
In a few isolated cases back in the day it did happen but it could've been a situation where the center hub of the pulley (any pulley not just ASPs) was hitting the aftermarket timing chain/sprocket or something.
Very little of that happening lately with the newer SFI Approved models.
