how do 01-02 ls1's pass emmissions since they dont have a.i.r. and egr?
Kleeborp the Moderator™
Originally Posted by jrp
hell, i got rid of air, egr, pcv, and my a/c. makes working in the engine bay alot easier ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
- D_Run: what type of emissions do you have in sweden?
![Fart](https://ls1tech.com/forums/images/smilies2/fart.gif)
I'm still liking my catch can setup...A LOT. At my last oil change, I had about a half cup of crap in there. I need to look in my manifold with a flashlight to see how it is doin in there...
Gotta keep my A/C though...I hardly use it, but there are some days in Florida when it is even too much for me. That and the g/f would prolly never ride in my car again.
Originally Posted by psykoTa
No, hes right. More valve overlap=more inert gas is retained in the cyinder=no need for EGR.
Originally Posted by HumpinSS
More overlap means there is MORE unburnt gasses leaving teh combustion chamber. During the overlpa period both intake and exhaust valves are open at the same time. This allows for un burnt fuel to enter the exhaust system.
More overlap=more burnt gas being retained in the cylinder, versus, say, no overlap, intake closed, exhaust open, most ALL the burnt gas will be pushed out rather than being mixed.
I can scan one of my old textbooks if you like. If I can find it
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
SN95 Director
straight from GM:
EGR ELIMINATED
Application of the LQ4 cam produced a valuable side benefit: elimination of the Exhaust Gas Recirculation (EGR) system. The new cam creates more valve overlap, or periods when both intake and exhaust valves are partially open at the same time. Increased overlap allows the LS1 to meet National Low Emissions Vehicle (NLEV) certification without EGR. Removal of EGR reduces engine plumbing and potential leak sources
EGR ELIMINATED
straight from GM:
EGR ELIMINATED
EGR ELIMINATED
#34
god damn ******* visual, always bites u in the ***, but might as well get it with non if im going to have LT's anyways cuz they would fail in itself, so **** it get the race style cuz id fail anyways if they look under the car.
#35
Same way I was thinking!
#36
Originally Posted by Phoenix57
reduces PLUMBING, not pinging
![Werd](https://ls1tech.com/forums/images/smilies2/werd.gif)
so if i order a set of QTP LT's race style (as in no egr or air fittings) will it still pass smog???
I just removed all my EGR/AIR stuff on Monday and I am a little nervous about inspection (not due until January 2006) but I will have all my codes deleted and hopefully some sort of fake cats under there by then so hopefully they won't notice too much.
