changing spark plugs
Old Oct 27, 2004 | 07:26 PM
00ws6blackbird's Avatar
Default changing spark plugs
Any tips on changing spark plugs?/??? The plugs on the passenger side look like they are going to be a b**** to change. Any suggestions are welcome......
Old Oct 27, 2004 | 07:41 PM
redbandit98's Avatar
http://www.installuniversity.com/ins...g_and_wire.htm
i would recommend a small 4" extension for your ratchet and possible a "u-joint" or "swivel adapter" as some people call it..or they make ratchets that swivel..either way it may come in handy on number 8..
Old Oct 27, 2004 | 08:07 PM
Matt D's Avatar
Retired Street Racer
Old Oct 27, 2004 | 10:49 PM
Full-Force's Avatar
go ahead and take the coil pack assembly off
Old Oct 27, 2004 | 10:58 PM
joshp14's Avatar
Removing the passenger side coil pack assembly makes things MUCH easier. I also disconnected the AIR tube from the exhaust manifold to get me some extra room.
The #8 is still a bastard though...
Old Oct 27, 2004 | 11:20 PM
God of Thunder's Avatar
run it up on some ramps and go from underneath. it made it a little easier for me.
Old Oct 28, 2004 | 01:38 AM
alright.....thanks for the info
Old Oct 29, 2004 | 08:05 AM
code4's Avatar
If you have the stock exhaust manifolds then do the right rear plug from underneath. I found out after installing my qtp headers that it's pretty easy to do all plugs from above now.
