header question
Old Oct 31, 2004 | 01:32 PM
TA_LS1's Avatar
Default header question
ok ive installed flowtech LT headers yesterday and it went well except for one problem. the connection between the y-pipe and the header on the driver side bangs on the floor under acceleration. what should i do to fix this?
Old Oct 31, 2004 | 01:47 PM
conan's Avatar
I had the same problem with my y pipe. I put a pry bar inbetween the floor and the pipe and pried on it then i took a piece of 1/4in round steel and bent it around a piece of 3in pipe so it looked like a "?" and welded it so theat the strait part hit the floor. Withe a piece or rubber hose over it it acts like a spring and keeps the pipe away from the floor. Sorry if its hard to understand Thats the best I can think to describe it You can also try to glue a piece of rubber to the floor to dapen the sound. I've read or a few people puting a poly motor mount it the drivers side so the motor doesent tq over as much. hope this helps.
Old Oct 31, 2004 | 01:54 PM
shortdog's Avatar
9 Second Club/Nitrous Mod
I just pried the floor board up a bit just enough for the y-pipe to clear. Problem solved.
Old Oct 31, 2004 | 03:06 PM
boosted03cobra's Avatar
thats what i did it worked
Old Oct 31, 2004 | 04:07 PM
SSTYCOON's Avatar
prothane motor mounts are known to work too, easier install will long tubes.
Old Oct 31, 2004 | 06:38 PM
shaulinmathvader's Avatar
Hey man how do the Flowtech's feel. Did they make a huge difference.
Old Oct 31, 2004 | 06:45 PM
davered00ss's Avatar
Moderator
Did not have that problem with my Kooks. But I would use a pry bar and lower the Y-pipe down.
Old Oct 31, 2004 | 11:39 PM
shortdog's Avatar
I didn't get the full effect from them until I got my car tuned.
Old Oct 31, 2004 | 11:40 PM
TA_LS1's Avatar
yeah LT headers do make a noticable difference, and the flowtech coated LTs are the best bang for your buck, but i was also told that when they hit against the floor i lose HP, so when i fix the banging problem, it may even be better.
Old Nov 1, 2004 | 11:55 AM
TA_LS1's Avatar
so if in order to stop the banging on the floor, i should pry the floor boards up? how should i do this? with a hammer? or is there any other way?
also there is a different smell coming from my exhaust. im assuming that it is b/c im running no cats b/c im pretty sure i installed my O2 sensors correctly.
Old Nov 1, 2004 | 06:25 PM
freakynipples69's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/229211-mufflex-ls1-hr-stainless-steel-hanger.html
Originally Posted by freakynipples69
as for the smell, yes its because of no cats. Its normal, if its the same smell im thinking off.
