Pulley bolt from hell.
Old Nov 6, 2004 | 05:16 PM
trigger1's Avatar
Default Pulley bolt from hell.
Well guys trying to swap in my TR224 and having a hell of a time w/ the crank pulley bolt. I have tried a 26inch breaker bar. I have tried an impact gun. I also have tried heat. Nothing seems to work. The car has had the cam replaced before under warranty. Could it be that when they had the bolt out they cross threaded it in which is making it such a PITA? Any suggestions are GREATLY appreciated.
Old Nov 6, 2004 | 07:42 PM
Z28Venom's Avatar
Is the pulley turning the motor over while you're trying to loosen it? The tranny needs to be in gear ( I forget which) .. that's if you don't already know this.
Old Nov 6, 2004 | 08:21 PM
Full-Force's Avatar
you need a new impact gun then ..... check out harborfreight.com and you can get a 625lb/ft impact gun for 79 bucks
I got one and if I let my compressor pump up tp 120 psi then that bolt is either gonna break loose or break.
When you try heat, heat the pulley and not the bolt.
Old Nov 6, 2004 | 08:27 PM
chpmnsws6's Avatar
put it in 5th gear and then try it.... if you can't turn it, go to the gym for a few weeks then try it again
Old Nov 6, 2004 | 08:30 PM
Z28Venom's Avatar
Old Nov 6, 2004 | 09:21 PM
LS198Z's Avatar
Breaker bar against the floor and crank the motor over with the starter (just tap it) it will break loose. Sometimes there is no room for an impact gun on various cars and this method works every time...
Full-Force's Avatar
harborfreight is the bomb
that 280 lb gun aint **** ... i got one of those too
get the earthquake gun ... i have it and its a helluva gun and it will do the job for you
Old Nov 7, 2004 | 02:29 AM
Z28Venom's Avatar
Why are you guys getting impact guns for this?
1/2" Breaker bar with a 3' pipe extension did the job for me.. All three times.
Old Nov 7, 2004 | 08:56 AM
chpmnsws6's Avatar
thats all i used also
Old Nov 7, 2004 | 10:23 AM
code4's Avatar
I don't like the thought of using an impact. The thought of pounding on the engine's main bearings doesn't appeal to me. I was able to break mine loose with one arm. I think mine was so easy because I have a huge 1" socket set. I think the ratchet is like 3 ft long, and it was on a lift. I just put it on there with the handle straight down, grabbed it with my left hand and the driver side tire with my right and gave a little tug. Make sure you are going counter clockwise to loosen.
Old Nov 7, 2004 | 12:07 PM
LS1Maniac's Avatar
Best advice yet!!
Old Nov 7, 2004 | 12:12 PM
trigger1's Avatar
Yeah that was number one on my mental checklist!
Old Nov 7, 2004 | 12:18 PM
LS1Maniac's Avatar
Last time I was at the track I couldn't figure out why I couldn't get my slicks unbolted. I was talking about how launching on the slicks must have tightened the bolts so much that they wouldn't come off with my tire iron. Then someone pointed out that I was turning the bolts clockwise instead of counter-clockwise. I felt like an idiot the rest of the night lol..
Old Nov 7, 2004 | 12:44 PM
Casperws6's Avatar
i had this exact same problem. impact gun didn't cut the job. took it to a shop i trust and they did it. i have a a4 so they held the torque converter and got it out. sure enough it was stripped at the end of the bolt.
it all worked out. good luck with your car
Old Nov 7, 2004 | 01:00 PM
Danny2tek's Avatar
Old Nov 9, 2004 | 07:36 PM
trigger1's Avatar
Well I took my panties off and slapped the 26inch breaker bar back on there today and gave her hell. after a few minutes she broke loose, Thank God!
Old Nov 9, 2004 | 07:49 PM
Z28Venom's Avatar
Good ole manpower...
Old Nov 10, 2004 | 06:46 PM
Oscar Will's Avatar
A long breaker bar and about a three foot piece of roll bar tubing, used the same setup to tighten it too!
Old Nov 11, 2004 | 03:40 PM
01_SuperSlow's Avatar
