Calling All True Dual Owners !!
Also, if you want to know the advantages of true duals... Do a search in this section for "true duals" and get a comfy chair. You'll find more info than you know what to do with.
After that, you'll love them. You'll break more necks from people staring at your car as you drive by. It's fun.
there are some clearance pictures for you...that is 3" duals over the axle...it does have some heat wrap on the driver side pipe...if i were you i would either go 2.5" over both sides or 2.5" over the passenger side only...with the second being better since you do not have to worry about melting anything on the driver's side...imo 3" is too big to go over the axles...it's been done a few times but you may find it to be more of a hassle than the power differnce between 2.5" and 3" the weather will make more difference than that...without a large cam and heads or forced induction there is really no need to go 3"
thanks
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
my pipes are about 1/4" from the lines...... havent caught fire yet in over two years, so i guess im alright.
