plug for EGR?
Old Nov 28, 2004 | 03:53 PM
ellis_juan's Avatar
Default plug for EGR?
What should I use to plug the hole on the intake for the EGR? I have Race ready headers and no plug for the EGR....thank in advance for the help
Old Nov 28, 2004 | 04:08 PM
HavATampa's Avatar
Search. A lot of guys have used rubber freeze plugs to fit in the manifold opening. It's been discussed a million times here.
Old Nov 28, 2004 | 04:19 PM
ellis_juan's Avatar
what size plugs?
Old Nov 28, 2004 | 07:10 PM
Full-Force's Avatar
1-3/8" freeze plug or 1-3/8 rubber expansion plug.
I just used a regular .69 cent freeze plug. Drove it in with a large socket.
Old Nov 29, 2004 | 11:06 AM
ellis_juan's Avatar
Thanks for the help man, while I'm at it, how do I remove the AIR pump?
Old Nov 29, 2004 | 11:27 AM
AdamSS's Avatar
www.ls1howto.com Look into Head/Cam swap procedure for F-body...
Old Nov 29, 2004 | 11:38 AM
Z28Venom's Avatar
Napa..
3/8" expansion plug is $3.00
Old Nov 29, 2004 | 12:07 PM
TheBlurLS1's Avatar
That's what she said...
remove as many panels under car (under driver side headlight) as you need to to get to the pump/bracket.
there will be 3 bolts holding the pump to the bracket which are horizontal. you remove these 3 and wiggle the pump around to remove it. there are also 4 bolts pointing up (you will be looking at their heads from under the car). if you remove those, the whole bracket + pump assembly will come out. i'm not sure if you can get to all 4 bolts or with the pump in place.
i did it this weekend. worked for about 3 minutes, then put some saftey glasses on after a few curse words some **** WILL fall into yer eyes so this is just a warning lol.
