Short Belt ??????
Old Dec 26, 2004 | 08:04 AM
BTLFEDSS's Avatar
Default Short Belt ??????
Just curious on the part # i know the belt is suppose to be 52" 6 rib correct?
BTLFEDSS
Old Dec 26, 2004 | 08:10 AM
ScottyG's Avatar
I have a Gates K060512. It's 51.2"
Old Dec 26, 2004 | 09:57 AM
BTLFEDSS's Avatar
That s for a stock pulley?
BTLFEDSS
Old Dec 26, 2004 | 01:34 PM
WJ SOM SS's Avatar
BTLFEDSS
Chad: Here's a Dayco Poly-Cog PS delete belt # for stock crank pulley: 5060525 (6PK1335). For ASP underdrive crank pulley: Dayco PS delete belt #5060510 (6PK1295). I gained .05 in 1/4 mile by using PS delete belt in my '99 M6 SS car. I gained NOTHING by using PS delete belt in my '02 A4 SS car. That's in 1/4 mile. Tried it many times on the A4 car--no gain. Don't ask me why.... WJ
Old Dec 26, 2004 | 07:01 PM
BTLFEDSS's Avatar
Thanks again WJ
Old Dec 26, 2004 | 07:14 PM
WILWAXU's Avatar
I've seen as much a tenth with my car. Albeit, my car is very consistant.
I had to replace my shortbelt recently. I suggest going with at least the 52" belt with an ASP pulley.
Old Jan 26, 2005 | 10:34 AM
slow3hoe2's Avatar
so you can bypass the ps pump without any problems? i used to do this on my fox mustang with no problem....but then i did it too my 95mustang and it shot ps fluid out of the pump fill. my car is a 99z. looking to do this at the track only. thanks
Old Jan 26, 2005 | 10:46 AM
JS's Avatar
JS
Wow Wil,u get almost a .10....
I gotta try it with my car too.....
Thanx for the info.
Old Jan 26, 2005 | 11:25 AM
LS1LT1's Avatar
Lightbulb
Same here, I've tried it on at least 4 separate track visits now with the car in various state's of tune and I just don't believe I gained anything. It's a pain in the *** to change back and forth before and after the track, makes that 180 degree turn at the end of the track a bit challenging sometimes and from what I hear can stress a stock steering rack a little bit.
No more short belt for me.
Old Jan 26, 2005 | 11:32 AM
slow3hoe2's Avatar
ya...typically gives mustangs a tenth...maybe the ls1 unit is more efficient
Old Jan 26, 2005 | 02:49 PM
WILWAXU's Avatar
Thanx for the info.
Joel, that was during my SI days.. haven't ran without it since the H/C.
