Coil Bracket removal
Old Jan 1, 2005 | 07:02 PM
Bluehawk27's Avatar
Default Coil Bracket removal
In the middle of this on my 02 hawk, the back passenger side is being a royal pain in the ***. Anyone have any tips or tricks to it? I've tried using a ractcheting 10mm rentch, help
Old Jan 1, 2005 | 07:05 PM
tomaSS's Avatar
Try a deep socket. It is tight but can be done. Be patient and take a break if you get frustrated.
Old Jan 1, 2005 | 09:50 PM
code4's Avatar
It took me all of 5 seconds. The trick is to use a pivoting head 1/4" ratchet with a deep socket, but you probably don't have one. Maybe you could find someone to borrow from.
Old Jan 1, 2005 | 10:11 PM
jd13's Avatar
The trick is to throw that bolt away after you get it off.
Old Jan 1, 2005 | 10:14 PM
nikon1999's Avatar
I just used a regular wrench and took my time, cursing slowly and repeatedly
Old Jan 1, 2005 | 10:17 PM
HavATampa's Avatar
Ratcheting wrench did it for me. Also did you remove the plastic cowl cover under the wiper arms? Gives you a little more room to work with when it's out of the way.
Old Jan 1, 2005 | 10:56 PM
Bluehawk27's Avatar
Well finally got it off, I went back out there right after i posted here, and got it in about 5 minutes. Weird how it always works out like that, a pivoting gear wretch got it done. After that i got to my springs real fast and everything went smoothly. This makes me want to buy the coil relocation kit.
Old Jan 2, 2005 | 12:12 AM
Danny2tek's Avatar
I spent two hours trying to get that bolt out. I finally gave up went to the parts store to get a gear wrench, I get back home my g/f hands me the bolt she says she got it out in 2 minutes
