QTP headers install ??
Old Jan 5, 2005 | 08:58 PM
fasteddyss's Avatar
Arrow QTP headers install ??
I just got my QTP's and am preparing to put them in this weekend. I have read everything I can find on this site but have one question for those who have done it.
The consensus seems to be that the car should be 20" off the ground.
Is the 20" under the wheels or 20" to the bottom of the rocker??
Thanks!!
Old Jan 5, 2005 | 09:01 PM
LS1LT1's Avatar
Thumbs up
Not exactly sure but the HIGHER the better.
Great choice of headers by the way.
Old Jan 5, 2005 | 09:02 PM
OldeSkool's Avatar
The higher you can get it the better. When I did my SLP LT's I used 3-ton stands in the back half way up and had to buy some 6-ton stands for the front and put them about half way up. Jack it up in small increments from side to side, and as always, be careful! I guess to answer your question, get it up about 20 inches to the bottom of the rocker and if they dont go in... raise the car up some more
Old Jan 5, 2005 | 09:17 PM
code4's Avatar
Thanks!!
Not sure of the exact height but I had to turn my driver side header straight up for it to go in without having to remove anything. Including the oil filter/plug.
Old Jan 5, 2005 | 09:45 PM
NviouSS's Avatar
how much do QTP's weigh compared to other headers?
Old Jan 5, 2005 | 10:31 PM
SmaknaSS's Avatar
This is definately the key to putting them in with no problems, makes it a breeze.
Old Jan 5, 2005 | 10:36 PM
02WS6Bird's Avatar
the boox i get them shipped in said 25#'s thats headers, header gaskets, 02 extensions, and Air Tube gaskets
Y-pipe and Strange 8 Locking header bolts are on there way soon back-order
Old Jan 5, 2005 | 10:43 PM
BlackVader's Avatar
I have a question for anyone ,I tried to install a set of hooker headers but the drivers side hits on the floorboard.Is it possible the engine is sitting or leaning to one side,and if so can you adjust on the motor mounts?
Old Jan 5, 2005 | 11:46 PM
psykoTA's Avatar
Poor quailty headers. There seems to be no quality control on them. Some fit like Kooks and QTP's, others hit every part under the car. How bad is it hitting?
I also need to know how high to get the car, 20" to the k-member doesnt seem like enough. Depending on how high I have to get the car, I may make 2 stands out of 6x6's.
Old Jan 6, 2005 | 12:31 AM
LS1LT1's Avatar
Lightbulb
Stainless from what I uderstand is lighter than mild steel so the QTPs should be measurably lighter than the likes of Pacesetter, Jet Hot, Hooker etc...factor in the weight of the coating and it's an even bigger weight savings!
Old Jan 6, 2005 | 07:32 AM
Durien's Avatar
nice choice.. i got the QTPs also...
I used a lift to get mine in ... i am a tall guy.. 6'4'' and i need the car to be very high off the ground for me to work under it..lol.... but they went right in without any problems..
good luck with the install
Old Jan 6, 2005 | 12:18 PM
S2002S's Avatar
I needed 32" under the nose fascia for mine. Be careful!
Old Jan 6, 2005 | 01:14 PM
Raptor99's Avatar
Sorry I don't have any helpful hints, but I just wanted to let you know that you made a great choice
I put mine in with the use of a lift.
Old Jan 6, 2005 | 02:06 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
I jacked the car up as high as my largest rolling jack would go (it's a 21" jack) + a piece of 4"x4" blocking was used between the jack and the K-member lift point. I had the rear tires up on Rhino ramps. So figure at least 2' clear from floor to bottom of K-Member.
QTP's slid right in. Slide them in with the collector aiming down.
Old Jan 6, 2005 | 04:08 PM
fasteddyss's Avatar
Thanks for the input guys!!
I have the car up about 20" now as I was rebuilding the tranny. I was going to put it on the suspension to install my new SFC's. I will see how high I can get it safely.
I have 2 huge jack stands I can use on the rear axle. I am making blocks out of wood to go under the front tires. I should be able to get over 2'
