BBK TB help!
Old Jan 22, 2005 | 11:47 PM
Z28camaro118's Avatar
Default BBK TB help!
I installed a BBK power plus 80mm TB on my 00' A4 Z28. I let the car run untill it reached proper temp, and when i went out for a drive the gas pedal is real hard to push down. If i push with force i burn rubber, and if ease into it it looks like im bucking. what could be the problem. Does it just need to be broken in?
Old Jan 22, 2005 | 11:56 PM
K I L O's Avatar
Same thing i have!!!.....but i also have a hissing noice at idle ....i also installed it today!
Old Jan 23, 2005 | 01:30 AM
Black Z/28's Avatar
Try here:
https://ls1tech.com/forums/showthrea...+2001CamaroGuy
Old Jan 23, 2005 | 11:12 AM
destroyerSS's Avatar
did you put in the spacer that came with the BBK?? and are you sure you put your T.P.S on correct
Old Jan 23, 2005 | 08:01 PM
Yes i put the spacer on first, w/ the bigger bore facing the lid, and then the gasket, the the TB. and everything that came off the stock TB i put the same way back on the BBK as it came off the stock. I dunno about the hissing noise though.
Old Jan 23, 2005 | 08:05 PM
git_sum's Avatar
Mine hisses too, i don't pay any attention to it though. As far as it stick just try adjusting your cable and the thing that holds it.
Old Jan 23, 2005 | 08:24 PM
smokeum99ta's Avatar
the spring is super hard at first on the blade but you'll get used to it.did you mean that you think its hanging up?mine did that and i had to adjust idle screw to stop that from happening.bbk said the vacuum from the motor makes the blade stick if you can believe that.keep adjusting it till you get it right.
Old Jan 23, 2005 | 08:30 PM
2001CamaroGuy's Avatar
the BBK blade is too big for the bore of their TB which causes it to stick in placed (quality controle is very poor on these things).......if you take some time to clearance the blade to the bore the it will work fine........I spent hours on mine...
