tsp duals problems HELP!!!!!!
Old Jan 29, 2005 | 12:35 PM
pontiac's Avatar
Default tsp duals problems HELP!!!!!!
ok i have the xpipe on and all three front peaces. but the bullets dont seem to be as far back as i need them so the hangers are at the floor pan??? any one esls had this problem? thinking about cutting about 1 1/2" of back part of the x pipe (the stiat part) so the bulletts will be farther back. any suggestions. Is my 9" the problem??
Old Jan 30, 2005 | 10:27 AM
WILWAXU's Avatar
to the top
Old Jan 30, 2005 | 01:54 PM
ILLWS6's Avatar
I had to bend the hangers to get them to fit right.
Old Jan 30, 2005 | 02:54 PM
Kennedy98z28's Avatar
I had to bend the hangers too.
Old Jan 30, 2005 | 06:42 PM
pontiac's Avatar
i ended up making ruber spacers about one inch thick on driver side and like 2" one passenger side. but workes.....OMG what a difference. thanks
Old Jan 30, 2005 | 08:21 PM
code4's Avatar
Ok, check out this pic. You can't get the hangars to go where mine are at? The mounting holes are drilled through at the back of the bottom rear seats.
Old Jan 30, 2005 | 11:20 PM
Crazy Man's Avatar
When you hang them I would take the back seat out and drill a hole for each hanger and bolt them up instead of using the sheet metal screws it came with. That way you dont ever have to worry about them wallowing the holes out and falling.
