Headers Vs. Stall Help!!!!!!
Old Feb 6, 2005 | 12:00 PM
TransLS1's Avatar
Post Headers Vs. Stall Help!!!!!!
Ok hey is my thing. i just bought a 98 TA it has a raptor cat-back, lid and stock exhaust manifold. Im limited on what i can get right now, besides all the little free mods and such. Im looking at pacesetters coated headers and Y-pipe ($499.98) or a TCI Super Street Fighter 3500 stall ($479.99). So i guess, how much HP would the headers and y-pipe give and what would my e.t.'s look like (the car runs 13.02 ) i know the stall would not give me HP but how much would it effect mt e.t.'s then the headers. anyone any comments plez
Old Feb 6, 2005 | 12:13 PM
Matt D's Avatar
Retired Street Racer
well here is the thing, like you said, the stall won't give you more hp, but it will help your et's a lot more than just headers and a ory will. i can't tell you from experience what my et drop was with each of these mods as i did my pacesetters with 3in duals and tci 4000 at once. but generally the tci 3500 will give you about a 3 to 5 tenth drop, whereas the headers would only be about 1 to 2. this is a rough estimate to due to a number of other things that effect your times like DA, track prep, weather, etc. i assume you are on stock type radial tire so if you get the stall first, which i would recommend, you should also get a drag radial to hook it. but if you do get the stall first, you also have to get a trans cooler, which is another $50 for a good one with 24,000 gvw. it is cheap insurance! so bottom line is pacesetters, the new batch, are good headers for the money, i have them on my car, but the stall is what you should do first. hope this helps!
Old Feb 6, 2005 | 12:23 PM
Rays C5's Avatar
The stall converter(aftermarket) will knock off more in terms of e.t.s than any header could dream of!!! It is the number 1# best mod for an a4. I went from 13.3x to 12.90 from t.c. alone. Thats a good choose you made.If you do alot of dragracingat the track and have drag radials I would get it on a 2.5 str.
Old Feb 6, 2005 | 01:44 PM
Crazy Man's Avatar
Stall For shure over headers.
Old Feb 6, 2005 | 01:53 PM
TransLS1's Avatar
Thanks a lot guys i like the feedback on this site. Rays C5 what is the difference in drang racing and daily driving in terms of STR. like you said if i drag race more get 2.5str. what is that. oh and i would be hitting the track ummm maybe once or twice every couple of months more daily driver then most. Thanks. Andrew
Old Feb 6, 2005 | 02:56 PM
69_YENKO's Avatar
get the Stall first!
And can STR even be accuratly determimed? isnt the 2.5 more of an estimate then a real number.
found this on precision industries(vigilante) website
http://www.converter.com/torqueratio.htm
just wonder if TCI can measure it.
Old Feb 6, 2005 | 03:06 PM
Matt D's Avatar
some companies like yank and tci test their TC's and know the true STR. TransLS1 don't go any smaller than a 2.5 str. from what you have told us, stick with the tci 3500 with the 2.5str, it will work great for your application.
Old Feb 6, 2005 | 05:05 PM
TransLS1's Avatar
thanks again guys. is it ok to buy a used stall or is that like diging your own ditch and asking for problems.
Old Feb 6, 2005 | 05:09 PM
Matt D's Avatar
the digging your own ditch thing
Old Feb 6, 2005 | 05:21 PM
69_YENKO's Avatar
your asking for it, unless you know they person & condition of it, i wouldnt do it.
i bought mine off LS1tech new from a member for a good price. you could probably find a used one thats been freashly restalled cheap.
Stuart
