WOT Issues
Old Feb 24, 2005 | 05:49 PM
01TAFlyer's Avatar
Default WOT Issues
At wide open throttle, and even under heavy acceleration the car does some backfiring, and what can best be described as sputtering. Recent mods include, longtubes and duals. Would this be suggestive of it running rich? I plan to try and pull a plug, and see what it looks like. Any suggestions? Also, no SES codes have been thrown.
Old Feb 24, 2005 | 06:48 PM
Sanders's Avatar
This happened to me. I was getting heavy backfiring under hard acceleration. I found a burned plug wire to be the cause. Check those out first.
Old Feb 24, 2005 | 07:31 PM
01TAFlyer's Avatar
I checked out the plug wires, and none of them appear, or feel burned in any way, none of them are touching the headers, #2 is close, but not touching. I could pull them, and check them with a voltmeter?
Old Feb 24, 2005 | 09:34 PM
racinbird's Avatar
Sounds more like a lean issue. the engine is now moving more air so make sure the fuel system is up to par....fuel filter and so forth. If it was that rich to be causing this then plugs would be black and you should see some black smoke out the pipes, also check for black soot on the pipe tips....just my .02
Old Feb 25, 2005 | 11:01 AM
99FormulaM6's Avatar
happened to me after headers and duals....everyone said it was plug wires, plugs, tuning, or loss of compression....but i reset the computer and it was fine after that. try doing that, but just remember it will run like *** for a few mins until the comp relearns
Old Feb 25, 2005 | 11:11 AM
~JOSHUA's Avatar
Lightbulb
It sounds silly, but replace your fuel filter and dump Lucas injector cleaner in the tank. My old LT1 did that sputtering stuff more and more. I was about to replace the opti spark, but I thought I'd try the fuel first. Cleared right up! Good luck!
Old Feb 25, 2005 | 12:20 PM
HAMRHEAD's Avatar
It sounds like what happened to me after I had my LT's installed. I had the computer retuned since I put in a cam and everything was fine. You may want to just diconnect it and let the computer relearn the set up. Will be cheaper!
Old Feb 25, 2005 | 01:43 PM
wvaboy's Avatar
if none of those options work, i would check to see if it might be moisture or a crack in the distributor cap. that's what it sounds like to me.
good luck.
Old Feb 25, 2005 | 02:53 PM
01TAFlyer's Avatar
What all needs to be done to completely reset the computer?
Old Feb 25, 2005 | 02:57 PM
01TAFlyer's Avatar
Turn key on, don't start car
Pull PCM BATT and PCM IGN fuses in the engine compartment
Wait 5-10 min
Turn ignition off
Replace fuses
Is this the best way to do it?
Old Feb 25, 2005 | 03:17 PM
racinbird's Avatar
good luck.
I didn't know LS1's had distributer caps?
Old Feb 25, 2005 | 03:29 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
When my first set of LT's went on, I had the same backfire issues. Tuning cleared up the problem.
Old Feb 25, 2005 | 03:32 PM
wvaboy's Avatar
racin, you're right, ls1's don't, lt1's do
my bad, should have read that in his signature.
Old Feb 25, 2005 | 04:14 PM
01TAFlyer's Avatar
Just reset the pcm, ran like crap at first, then seemed to get a little better, but now have an ses light
After a couple cycles I let you know how it is going. Also, any other ideas are welcome, and thank for you those already submitted
Old Feb 25, 2005 | 04:22 PM
!LS1 11 Second Club
What's going on with your rear O2 sensors?
Are they still on there? If not, you need to have the rears deleted or use O2 simulators (which don't work very well). Also, with LT's, welcome to the world of replacing front O2's every so often.
Old Feb 25, 2005 | 07:53 PM
69_YENKO's Avatar
mine has done this a few times too, it seem like it dose it more on like 1/2--3/4 throttle then at WOT. im hunting for a problem/fix right now, if i find one i'll let you know.
Old Feb 25, 2005 | 09:32 PM
01TAFlyer's Avatar
I no longer have rear o2 sensors. I had them deleted. Front o2s causing a problem then with the a/f?
Old Feb 26, 2005 | 08:09 AM
JEB99TA's Avatar
In my case, at high rpm's, it would smoke black and backfire on deceleration (raz/fuel lightoff in the exhaust). While on the dyno, it backfired and shot 6"-12" flames out the Borla's. Once I replaced the .035 gapped TR6's with TR 55's gapped at .045, it helped the idle issue a lot and it completely stopped the backfiring on deceleration.
Old Feb 26, 2005 | 08:58 AM
!LS1 11 Second Club
Scan the code thrown and you'll be 100% sure of what's going on now.
Old Feb 26, 2005 | 06:09 PM
JEB99TA's Avatar
I'll have to pay someone to do it for me. I think I'm gonna' have NLP do a leak-down test and scan the codes to identify and fix whatever the issue is. It must be something tuning can fix. I say this because my car is a -99, but, it obly has 37,000 miles on it. Surely it can't be rings. I just wanna' get it resolved before I have NLP install a 100 wet shot.
