Remove Cats... Sound?
Old Mar 8, 2005 | 11:30 AM
Runn's Avatar
Default Remove Cats... Sound?
If i remove my cats, how much louder is my car going to sound?
Old Mar 8, 2005 | 11:31 AM
GregWS6&z28's Avatar
raspy, but nice in most rpm's other than 2000-2600 range
Old Mar 8, 2005 | 11:41 AM
Runn's Avatar
Is there a big change in volume?
Old Mar 8, 2005 | 11:48 AM
WS-Sick's Avatar
www.ls1sounds.com
Your car will definitely be louder.
Old Mar 8, 2005 | 12:04 PM
HAMRHEAD's Avatar
Louder and raspy!
Old Mar 8, 2005 | 12:35 PM
rubber duck's Avatar
I'll put it this way, when you start it up you'll look under the car to make sure you clamped the cat-back on properly, don't worry, you did, it's just that loud.
Old Mar 9, 2005 | 11:04 AM
Runn's Avatar
Thanks for the answers, Still not sure if i should remove my cats???
Old Mar 9, 2005 | 11:19 AM
One Bad Z's Avatar
What cat-back do you have, stock? The only catback without cats that i consider raspy is the slp loudmouth and it doesnt just sound raspy it sounds like ***!
Take the cats off, you will like the sound.
Old Mar 9, 2005 | 11:26 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
It's defiinitely louder. I had the SLP Loudmouth on my 'bird. After removing my cats and installing longtube headers, it sounded good at idle but was really raspy upon acceleration. I loved how loud it was, but didn't care for the rasp at all. I ended up doing the "Dynomouth" mod and it cured the rasp, but left the volume basically the same. Now it sounds great.
If you don't want it loud, then I'd leave the cats on.
jimmyblue's Avatar
Moderator
I gutted mine. I have the SLP CME exhaust ("factory" SS option)
and the idle note got a little louder but it's still mellow and just
healthier sounding. Not an attention getter, just a little looser
in the throat. A little more boomy at 2000-2500RPM. A little
louder up top I guess. But nothing like when the cutout is open.
Now, if you had something like a Loudmouth, then the cats are
your only remaining muffling and taking them out, you're letting
a lot of high frequency nastiness right out the pipe ("rasp").
A very low restriction aftermarket exhaust, probably close in
degree. The more restrictive factory, base exhaust, probably
even less noticeable than mine.
I think the best way, if you want to stay stock configuration,
is a pair of the Mufflex or similar offroad tubes. Those should
boom less than gutted cats (which become then just resonators)
and fit right up. Damn expensive for being just two feet of pipe
with flanges on the end, though. You should be able to get a
used set of cats and bust the bricks out, for near nothing. Even
over there. Then swap those on and keep your (presumbly working)
ones for later, in case you or the emissions police decide you need
to go back.
Old Mar 9, 2005 | 11:27 AM
texada's Avatar
LOUD! I have macs/oryp and ultraflow dynomax. I will be putting on some magnaflow cats this week. I have an a4 with a 3200 converter and it is real raspy 2000-2800 which is where my car stays when just easing around town. It is quiet when the converter locks up and sounds like a race car when I floor it!
Old Mar 9, 2005 | 11:28 AM
SScreaminDemon's Avatar
What is the Dynomouth mod? I took my cats off, love the sound and hate the rasp.
Old Mar 9, 2005 | 12:28 PM
Runn's Avatar
I have a flowmaster on right now, And i am thinking about buying QTPŽs LTŽs with ORY.
Old Mar 9, 2005 | 02:51 PM
Quick 99's Avatar
your car will be alot louder, but it will get pretty raspy depending on the cat back or true dual system you are running. I dont mind mine but you may not like how it sounds, your best best is to go to a site like ls1sounds.com and see what the difference in the exhuaast note is or listen to someone elses
Old Mar 9, 2005 | 05:45 PM
you weld a a dynomax bullet in place of the loudmouth resonator. You'll still get some rasp, but not nearly as bad as with the resonator.
Old Mar 10, 2005 | 08:23 AM
DJ_951's Avatar
Have a mac ory and a dynomax muffler sounds great.
Old Mar 10, 2005 | 11:07 AM
Pegleg's Avatar
I just got my cat gutted on my Loudmouth. I have an LT1 though. When I get the car back I will let you know how it sounds
Old Mar 10, 2005 | 12:15 PM
CRASH Bandicoot's Avatar
Take the cats off and run it with a loudmouth. It's quiet as a mouse In all seriousness, I like loud cars and a little rasp or interior drone doesn't bother me. If you take the cats off get True Duals, catbacks sound like **** without cats.
Old Mar 11, 2005 | 04:56 PM
Stang_Killa's Avatar
Duh
Old Mar 11, 2005 | 08:11 PM
psykoTA's Avatar
Is the rasp coming from the resonator itself, or the the y-pipe junction? If you had a flo merge collector, would you still have that rasp? Maybe the resonator amplifies the rasp once the cats are gone?
