SLP fan switch
Old Apr 2, 2005 | 07:04 PM
PontiacTA99's Avatar
Default SLP fan switch
Is it an easy install? How long should it take to do? I have FTRA so I should really do it.
Old Apr 2, 2005 | 07:08 PM
snake charmer's Avatar
I installed mine in about 15 minutes. I made it real clean by taking the glovebox off and running the wire behind it so no wires are showing. I drilled a hole in the ashtray for the switch. Really easy install.
Old Apr 2, 2005 | 11:41 PM
M6HuggerSS's Avatar
easy install... i removed my computer so i could use a the same hole in the fire wall...
i took my time, took about 1 hr total...
i think its a GREAT mod! i use it all the time.
Old Apr 2, 2005 | 11:57 PM
blkZ28spt's Avatar
Yup, it's very simple. I also ran the wire through the hole behind/under the computer. (passenger side, just in front of windshield, just inside the fender) I hardly ever use it now that I've had it tuned (fans come on earlier) but it sure did help with keeping the temps down during the summer in the meantime.
Old Apr 3, 2005 | 12:59 AM
SStheBest's Avatar
yup yup...and with me going to Florida this june.....there gonna stay on....dont have the 160dg thermostat
Old Apr 3, 2005 | 03:49 AM
Redneck Z's Avatar
It is easy...but I don't see how 15 minutes is possible, unless you've done it before, and then maybe 1/2 hour. It took me about an hour. I took the bolts off the computer and moved it to the side, without taking it out. I went through the factory hole, zip tied the wire to other wires under the passenger side dash, then ran it under the center console to the ash tray. I think this is a great place to mount it. If you ever decide to take it out, you can just pick up a new ash tray, instead of having to cover up a hole in your dash. Great mod.
Old Apr 3, 2005 | 03:08 PM
Danny2tek's Avatar
Does it come with enough wire to maybe mount it inside the flip off center console?
Old Apr 3, 2005 | 04:26 PM
WILWAXU's Avatar
Should be plenty of wire for that. My switch is mounted right below the lighter.
Old Apr 3, 2005 | 05:18 PM
CRL 01 SS's Avatar
Installing the SLP fan switch is very easy, and takes about 15 minutes to install. It comes with instructions, plugs right in to the factory harness and then all you have to do is ground it and run the switch into the cockpit through the hole behind the PCM.
Old Apr 3, 2005 | 06:16 PM
Thanks everyone sounds like an easy install.
