LS6 intake/coolant pipe
I thought of this because I've heard of people using 2 01+ coolant pipes, so there shouldn't be a clearance issue in the back right?
-j
I would like take this opportunity to express my hatred for my car...
Everything was going semi-smooth. Had the old intake off after only about 45 min. and 300 cuts on the top of my hand. Was removing the little green clips that hold the knock sensor wire(i think) to the coolant line. Well wouldn't ya know the one in the back was broken under the tape. While removing the tape, the little green piece of clip jumped and flew as if guided by sonar directly into the far back passenger side intake port on the head.....
Thank god the valve wasn't open enough to let the little piece of **** fall down into the cylinder. Took a good hour to get the damn thing out. Tried to suck it out, blow it out, tape on the end of a small screwdriver, and finally some type of medical device my friend brought over to snag it and pull it out.
With that finally out of the way, I had to mod my stock coolant pipe. I cut the rear section and connected it with a small coolant line and hose clamps. As for the front, I got lazy and ran out of hose clams and decided to smash the hell out of it in a vice and put some gasket sealer in/on the end of it. Didn't work. Now its time to head to work. I'll have to mess with it later. Hopefully I can pull that front coolant pipe off and mod/replace/fix it without removing the intake manifold.
I also have some gut feeling that the back isn't seated all the way and there is a air leak. And also noticed on startup that my Y pipe is cracked... again. (dont go with flowtech) For all the do-it-yourselfers, order the 01^ coolant pipe, its not worth it.
-j
I did my LS6 intake yesterday too, but i had preordered the front hose and 2 plugs for the rear. Being my first time it took a lot longer than i thought it would, and i had a helper too. If you are about to do this remember that once the intake is unbolted you will need to leave the loose rear bolts in the manifold and then pull it out, dont forget to put them back in the new intake before setting it in the engine bay. The 2 hoses and 1 connector on the back of the intake are a bitch. I found that turning the unbloted intake sideways allowed me to gain access. I bypassed the t/b. as well. The thing i was most worried about was that if the rear plugs leaked, i would have to take the intake manifold all the way back off to get to them. Luckily they did thier job just fine.
The idea of cutting the stock coolant hoses off the plus and welding the holes up for plugs did cross my min to save a few bucks, but in the end im glad i did it the right way.
BTW, the car is definitely faster. Not "holy **** its like nitrous" faster, but it gets to redline quicker and even sounds a little different. Not the exhaust but the sound of the motor(easily heard over the quiet stock exhaust).
Is there a way to check with a mity vac how much vac the car is producing at idle? Which hose should I tap to check? I'd like to see if there is any air leak. After checking the intake it looks flush along the top with the head so there shouldn't be a problem.
-j
