Need Exhaust Advice....
Here is what i've thought of...
1. Put everything back to stock except the catback and run the cutout open.
2. Put a (Flowmaster 1 chamber, bullet or Borla XR-1) before the cutout and open the cutout, only problem with this is if I ever want to close the cutout I'm not sure you would hear the car running. The Magnaflow is very quiet on my car..
3. Sell the cat back and run one of the 3 muffler listed above after the Y-pipe.
4. Sell the cat back & Ory and run true duals.. (not sure the car would run well?)
Sorry for the long post just kinda at a loss and lossing sleep due to mind consumption..
Kevin
Thanks for everyones suggestions so far...Keep them coming..
Kevin
Too loud? Too quiet?If you don't like the nasty rasp, you have two choices to fix this...Have some highflow CATS welded into your Y (which will kill all of the rasp and deepen/clean up the tone). It will make it noticeably quieter this way, but your car will also sound a lot better. OR, ditch the Magnaflow cat-back for a 2.5" (since you have MAC's) X-pipe set-up to dump or run some true duals out the back. Unlike "single" exhaust set-ups (cat-backs/Y-pipe), duals actually sound very good without cats and they are not raspy. Just very loud, especially if you dump some Dynomax Bullets or Flowmaster 1-chambers. But the tone is extra mean and would sound much better (deeper/cleaner) than your current set-up.
As for performance though, I don't quiet see how you're disappointed in it?? Your MAC mid-lengths won't give up anything to a set of longtubes on your stock internal car (and they'll about match 'em up to a solid 400rwhp). Only thing you might gain is a little under the curve with the longtubes, but that's it. At least from what I've seen of others who've made the switch. And you wouldn't really gain anything at all (peak-wise) with X-pipe duals, but you'd definitely gain under the curve with them as compared to any Y-pipe cat-back.
Either way, hope I helped some and good luck!
Mike
You're car might be running rich after them, so you might need to have the Air/Fuel ratio adjusted to be leaned out some (ideally 12.9-13.1 for N/A LS1's). If I understood you correctly though, it seems like you want a loud car, but without any rasp...So either put some cats back on the car and run the cutout open or dump the Y-pipe/cat-back for the 2.5 X-pipe true dauls I talked about...Either way, you'll be much happier and still retain all the power you want...
. The rasp between 2000 - 2800 is still a little annoying however I'm starting to get used to it. I'm still considering putting in a bullet before the cutout but we'll see... Thanks again for everyones input and comments. Kevin
Mike
