Pulley Removal Issues(help!)
i started with a 5 ton. could not get it to fit without removing fans/rad
so, then i got a 2 ton. fit, quickly broke it.
found a 3.5? ton, this fit. could not keep it on the pully under heavy torque load.(i was flexing the threaded rod with every turn-i was using a 3ft breaker bar
)notes
all were internal 3 claw pullers
yes, i did remove the bolt!!!
how are these removed in your driveway? short of using a low yield nuke?
Edit: I used a ghetto version of the longer crank bolt. Are you getting any progress on it?
i thought about heating it up with propane but, decided this might not be a good idea.
this car fights me on everything. (98 SS 9200.00 miles) i miss working on my 5.0's
I fought with the stupid puller for awhile just trying to get all the claws on AND the threaded rod in place. It only wanted 2/3 claws to seat.
hey, do you remember what the part number of the one you used was?
i don't understand why the pulley isn't threaded like a ford. 1000 times better set up imo.
Is the autozone rent-a-puller a 2 or 3 jaw guys? Just wondering because I want to buy a puller for my own use. I see some on sears' website for around 30/40 bucks, so that's not too bad, esp if I use it more than once.
Thanks!
-Alex
room is at a premium under there. i used three different extenions along with several swivels tring to use my impact on the bolt. that didn't work (figured that out when the swivel shot past my head
