where to get longer crank bolt for install?
Old Apr 21, 2005 | 11:53 AM
bigken's Avatar
Originally Posted by Steve Burger
We put the pulleys in the oven at 200 degrees for about an hour. Take it out with oven mits and it will slide on the crank most of the way. This has worked every time.
your kidding right
i think i would have to see that to believe it
Old Apr 21, 2005 | 03:05 PM
Steve Burger's Avatar
LS1TECH Sponsor
The heat from the oven expands the metal on the pulley. No I am not kidding.
Old Apr 21, 2005 | 03:14 PM
1jfuddle's Avatar
Does it shrink back to normal size and maintain balance??? That might just be a really good idea.
Old Apr 21, 2005 | 03:29 PM
SS SLP2's Avatar
get 2 stock bolts fron dealer weld them head to head grind down the heads so it will pass inside pulley get a nut and washer and you are set to go
my $0 02's Johnny
Old Apr 21, 2005 | 03:50 PM
LS1TECH Sponsor
Yep, think about it. Metal expands with heat. You are heating the pulley and not the crank. Both will expand as the engine warms up. In this case you are expanding one and not the other.
As it cools it will return to normal size. Heating it has nothing to do with balance. If the pulley can't handle a 200 deg. temp for an hour it should not be under your hood in the first place.
Old Apr 21, 2005 | 04:30 PM
240M3SRT's Avatar
What about heating the earlier asp style pulleys that have what looks like an aluminum inside connected to a steel outer by rubber(cant tell if this is actually what holds the 2 together)?
If no oven at the shop then i dont guess a map gas or propane torch is controllable enough, whould prolly melt the rubber right out like when you do urethane bushings?
Old Apr 21, 2005 | 04:45 PM
LS1TECH Sponsor
I did my older ASP pulley this way. Underhood heat is a lot hotter than 200 deg. so I don;t see a problem.
Never tried a torch. Always took the pulley in the house and baked it. My wife still laughs at this
Old Apr 21, 2005 | 07:29 PM
Black Z/28's Avatar
Originally Posted by 2xLS1
Right guy. I just took so much abuse here for selling them, I quit.
I'm glad I got your tool before you stopped selling them. It's exactly what you need to do the job. I read all those posts criticizing the tool (and price)- what a bunch of dumbasses.
Old Apr 21, 2005 | 08:37 PM
777's Avatar
777
M16x2.0 Good luck finding a threaded rod less than 1M long.
you can always cut it
Old Apr 21, 2005 | 09:07 PM
2xLS1's Avatar
I kind of figured that out since I sold the tools. It is the cost of buying 1M lengths of threaded rod. Go price some.
Old Apr 21, 2005 | 09:29 PM
Stark's Avatar
I called a local tool and die shop and they gave me the number for MSC tool company.
(770) 732-8650
They sold me a 16m rod 2.0 pitch 1 foot for $6.78
Nuts were $0.13
I too bought the longer bolt but the more i read about people stripping out the crank, i want a solid plan B. When i start my cam swap on monday, i would rather not spend my mod time running around town looking for a tap to fix something i shouldn't have broken in the first place.
Just my $0.02.
Old Apr 22, 2005 | 05:18 AM
  #32
1jfuddle's Avatar
I have spent the night up putting my engine back in my personal car. I put the pulley (ASP) in the oven and WOW!!! That thing just slid right on. That has to be the easiest pulley install I have ever heard of. No more banging a piece of wood or trying to track down threaded rod for me folks. Just throw it in the oven. It slid on so well that I could tighten down nearly the entire length of the threads by hand. Thanks for the advice!
-John
Old Apr 22, 2005 | 08:26 AM
  #33
LS1TECH Sponsor
Ahhh... A believer. Glad to hear it went so well.
Old Apr 22, 2005 | 09:07 AM
  #34
240M3SRT's Avatar
I will be doing my UD pulley tomorrow and i was hoping someone could walk me thorugh it step by step, since i cant find the instructions on ls1howto. What kind of pulley remover do you use? Rent one from autozone? Is removal where you need the breaker bar and lead pipe or will an impact wrench work? Do i need to buy the longer bolt for installing the new pulley?Etc? Etc?
I can either choose a lift, a friend, and $100,000 worth of tools at my buddys shop or an oven at home by myself? Im thinking the first.
Just want things to go smooth it will be at night so i need to have all the parts ready to go nowhere will be open and i dont wanna get 1/2 way through then be like F---!!!!
