asp pulley install
Old Apr 21, 2005 | 11:46 PM
dubrado's Avatar
Default asp pulley install
bout to install this damn thing
what can i do to keep the motor from turning over, I have an A4. Can I put it into gear before hand to prevent that?
I read that it's beneficial to see a longer than stock bolt w/the new pulley?
thanks in advance
Old Apr 21, 2005 | 11:52 PM
Lithium's Avatar
SSU's Drunk Typing Whore
On an A4 car, you will need to drop the starter, install an flywheel locking tool, or you can also just wedge a screwdriver in.
Old Apr 22, 2005 | 12:07 AM
dubrado's Avatar
isn't there a cover or something I can pull back? or do I have to drop the starter?
Old Apr 22, 2005 | 12:12 AM
santino04's Avatar
Bingo on that! I personally dont think the ASP pulley needs the longer bolt to install. I put my pulley in the oven at 250 to expand it and it slid on a good way. The bolt screwed in quite a ways and pulled on the pulley nicely. Also with the ASP pulley you may fear that its not seated on all the way because of like an 1/8th inch gap between it and the timing cover. From what Ive researched it seems to be normal. Im still praying til this day hahaha. Good Luck
Old Apr 22, 2005 | 12:13 AM
santino04's Avatar
Yes the torque convertor trans inspection plate I guess you call it. Little silver plate on bottom of the housing.
Old Apr 22, 2005 | 03:57 PM
dubrado's Avatar
it also says to "grease" the pulley? that necessary? with what and on what part of the pulley?
Old Apr 22, 2005 | 06:03 PM
ss rally red's Avatar
Just put a light coating of bearing grease on the inside of the pully that slides up on the crank.
