ls1 power steering
Old Apr 23, 2005 | 12:24 AM
1hot91's Avatar
Default ls1 power steering
my resevoir is cracked, can i replace just that or do i need a whole new pump? anyone know what they run new?
thanks in advance.
Old Apr 23, 2005 | 08:16 AM
72ChevelleConv.LS1's Avatar
Yes you can replace the rez. I did it on my f body pump you remove the pump then remove the bracket that holds the pump to the bracket. then tap off the steel brackets that slide on to hold the rez and pump togeather. you dont remove the pully. pull the rez. off and install in reverse.
Old Apr 23, 2005 | 03:50 PM
1hot91's Avatar
thank you for the reply, anyone know where i can get a new resevoir then?
Old Apr 23, 2005 | 04:09 PM
LoudmouthLT1's Avatar
Gm...
Old Apr 24, 2005 | 03:34 PM
1hot91's Avatar
thank you.
Old Apr 24, 2005 | 03:38 PM
CRAGER's Avatar
Administrator
Try to find a part number on it and look it up on GMPartsDirect.com for about half the price then going to your local parts counter.
Peace,
Craig.
Old Apr 25, 2005 | 11:10 PM
WILWAXU's Avatar
Peace,
Craig.
Or just call SDPC >>-->
Old Apr 26, 2005 | 01:32 AM
1hot91's Avatar
well just in case anyone else runs into this problem it's $30 from gm. thanks guys.
