bassani true duals?
my original thread with dyno results rom both of my cars and 98t56TA
https://ls1tech.com/forums/showthrea...hlight=bassani
my dyno test of borla vs bassani tru-dual
the sponsor special thread
waiting for the steel cartel to decide they have enough money and drop their prices first. this particular grade of stainless ss T439. The 439 stainless steel has a higher nickel and chromium content than t409. other companies use T309 and T409. so, when pricing systems, look deeper into what it's made out of. there are many different types of stainless out there. until then, the aluminized is the next cheapest at 799.00 considering you are replacing the entire catback + the y-pipe, that's good deal. i priced the borla at 800 with the slp y-pipe at 200 in the sponsor special thread. and i made 15 rwhp more over the borla system. another person made more over the magnaflow system. but, yes, you can get more out of doing a cam, intake and valvetrain at the same price. but still leave some power on the table. there is also lanes and TSP dumped duals as well. Last edited by mrr23; Apr 30, 2005 at 10:19 PM.
Considering the airflow increa and subsequent supporting modifications required (such as intake system and tuning) to tune it, you're bringing in a whole other set of variables that may effect net results if you indeed compare it to a common catback y system. The Bass is assembled for each car individually, with more research and design time than some of the custom dumped systems where fitment is less crutial.
If you look at the cosmetics as a different characteristic, the system exits out the original locations, which on TAs makes the whole setup that much more effective without the additional cost of custom plumbing or welding. High velocity airflow (ie, lots of rpms) work well too because the system rivals cutouts for total flow actually...there are no baffles or chambers in the entire length. I was surprised at how the total flow of the system was rotated in the positive direction. Not what I expected nonethess solid gains and a good foundation for cam heads or whatever else.
Now, since the bassani is both mandrel pipes and true dual with siamese x pipe...even on a bolt on car the cost/gains ratio is favorable for roll ons or the track. There could be several combinations with the bassani, including shorties, or stock manifolds, mid length and even long tube headers, all of which will show positive increases in airflow based on any of the existing catbacks.
Now here's results of my exhaust endeavors. This is with 200 n2o.
distance ---stock ----- cutout --- Bassani
60ft ------ 1.987 ------ 2.074 ----- 1.969
1/8 ------- 7.902 ------ 7.912 ----- 7.739
mph ------ 93.20 ------ 93.97 ----- 98.60
1/4 ------ 12.102 ----- 12.080 ---- 11.814
mph ----- 117.12 ----- 118.06 ---- 121.35
i lost torque as you can see by the loss in 60ft time. by the 1/8 mile the cutout caught back up to the stock system. then in the 1/4, the cutout gained me 1 mph. overall, i gained squat in the 1/4 mile ET. andi still have stock manifolds and cats to boot. i'm waiting on the tri-y headers bassani is developing right now for the f-bodies.
yes it's hard to justify when you already have an exhaust system. understood. but, as you can see, everyone that has reported with actual dyno/track results, have gained. yes, there are cheaper systems out there. which goes back to what materials they are made of. and how much material used as well. duals have more materials used because of the second pipes. 98t56TA just showed it beating a magnaflow system. you've got to look at the price difference between the two with the additional gain to see if it's worth swapping for you. and you can sell yours as well to offset the cost.
Right now it makes the numbs in my sig with shorty headers.
